06 MR stock spring rates
Best Motoring DVD ... the difference is because of the dampers ... how to you explain the EVO which has soft spring rates than the STi having a stiffer and harsher ride? It's because of the dampers ...
On the other hand, who knows I might be completely off ...
As I said BMI, its the Factory fighters episode. They show the differences between the EVO 7, 8 and MR dampeners. And yes dampers do make the car act stiffer ... I'ld rather not get into a technical debate but ask anyone with coilovers that have different dampener setting for the track and the street ...
Originally Posted by JohnBradley
A softer damper would NOT MAKE the car act stiffer with a soft spring. That is counter intuitive.
Actually damper or dampner are both acceptable english.
Argh! didn't I tell you I didn't want to get into a technical discussion ...
Ok, in an ideal world springs would do exactly what springs are supposed to do, absorb bumps and dampeners (shocks) would do exactly what dampners are supposed to do, absorb the oscillations of springs (aka dampen). But in the real world, this same device that provides dampening has to provide a force that resists the motion of the spring. Without getting into the specific types and designs of dampener (really I don't want to get into too much technical detail as I will be typing forever), dampener are pistons with valves that sit in tubes filled with oil and compressed air. These shock settings in adjustable dampener control the size of the valve which determine the rate of flow of oil through the piston when a certain value of force is applied to the piston.
As you can see the size of the valve controls the rate of flow, which in turn controls the resistance/stiffness ... go too soft with the dampening rate with a stiff spring and your car will continue to bouncy as if you had no dampeners, go too stiff with the dampening rate with a soft spring and the dampener will take on some of the role of the spring (aka EVO GSR and RS) and there might be a delayed reaction by your suspension if your dampeners are a lot stiffer than the springs. Remember there is alway a certain range where you can play with your dampener settings to match the spring rate you have chosen without getting the delayed reaction which will make your car unpredictable = bad.
As you can see because of the nature and design of the shocks them selves they act as helper springs.
Hope that helps
Hope that helps
Yes, I understand that 05 & 06 MR's are the same spec but why than why do Works, Swift and few other Companies offer MR specific springs? And when I spoke to Japan parts -Japan- concerning Raliart springs for my MR I was told that they were just available for the KYB spec Evo's and not the MR spec. I'd like to think that Mitsu actually did just a little more than R&D W/Bilstein just to slap a stock US spec Evo spring into it in the end.
Same as the 05 MR which in turn is the same as the stock EVO spring rates.
MR shocks are 30% less stiff but react quicker to bumps in the road. Springs are the same vs. non MR.
MR specific springs are designed to work with the Bilstein design and capability...at least the ones from Swift are, its what Im running.
This is because as springs have a dampener range they can be used with, without going over the limit and deteriorating handling. Likewise dampeners have a spring range they can be used with them, since the stock EVO (GSR, RS) dampers are ~42% stiffer than the MR dampeners (its the same as saying the MR dampeners are 30% softer, yes math is weird) the range of spring rate that can be used with the bilstein dampeners are lower (different). Therefore if a manufacture designs a spring for the stock GSR/RS dampener using the upper range of the dampener it will be far above and out of the range of the bilsteins.
I noticed my spelling sucks ...
