I need help from the tire experts.
My situation is that I have two nails pulled from one tire and the nails were about 2 inches apart so he can't patch it up because the patches will overlap. I am credited one tire so I was wondering if I could get 245/45/17 for this tire and wait till the others wear out enough to replace them all to the same sizes. I mean is it okay since i'm running this tire on the rear? Thanks for your help.
id go 245/40/17...but anyway
I guess you could do that, depending on how much tread is left on the others. Itll be inda wierd nexty time you change the tires cause theyre all gonna wear a little differently. Id say just change two of em or something like that...
I wouldnt recommend putting one different size tire on an AWD car. You actually should replace all 4 tires together when you need to replace one so the tread depth is the same.
As for repairing that tire, they make different size patches. You should just get a larger patch and you will be fine. Check your auto parts store. At my last job we had 2 different size patches that we used.
Originally Posted by Neal@tirerack.
Shouldn't put an odd ball size on one corner of any car let alone an AWD. Those are about 1/2" wider and taller than the oem size. That's enough diff to cause driving and differential issues.
BluByWho
For Sale - Wheels / Tires
Jul 28, 2008 08:56 AM
er0e
21
Sep 5, 2006 02:38 PM
