Full Cusco....or which
alrighty, im thinkin of a real nice suspension set-up for the evo, and for now i do have stock suspension.....im wonderin is there any better or what would all suggest......i planned on this....
1. Cusco 25mm Front Sway Bar
2. Cusco 23mm Rear Sway Bar
3. Cusco Triangle Front Tower Bar
4. Cusco Rear Strut Tower Bar
5. Cusco Type 2 Lower Arm Bar
6. Perrin Rear Sway Bar Endlinks
or would anyone suggest the JDM Beatrush parts......Anyone with experiences with either of these parts?...or better ones....also i dont know what type of coilovers to get or if i should get coilovers....i mean im not a big suspension tech...but im jus lookin to stiffin up the car for cornering and such....would Tein Flex coilovers be any good.....any info at all on this would be great....thanks alot
iv continued to search on this and iv decided to scratch out the front sway bar and maybe a Perrin Rear sway bar with the perrin endlinks.....i jus dont want the rear of the car to become loose or have a big tire lift i jus wanna stiffin up the car for corning and such.....no one has a comment?
most people will tell you if you are only driving on the street, sways are overkill - stock will do just fine
save your money on endlinks - not needed
Cusco front brace - looks nice, but no improvement vs stock. If anything, get the titanium, as it least its alot lighter (5.5 lbs lighter) than stock
Most do the type 1 and type 2 lower arm bars - they work great. I would also do the rear "V" brace, as it makes a nice difference, or go for the GT Spec trunk cage if you don't mind losing trunk space. The rear trunk brace from the RS, or the shinier one from Cusco is also a nice addition and cheap
Originally Posted by 4 Wheel Slide
vivid sells a 27mm rear swaybar now...
At most get an adjustable 25mm rear sway and keep the front stock. Keep it at the low setting on the street and then crank it up on the track. You do not want a front sway. If you add the front sway you will corner "flatter" and lift the inside front tire while turning. This will give you a false sense of better handling, but you will be slower.
Originally Posted by .MM
you should start with a good coilover system, then use sway bars and other bars to further tweak and tune the car to your liking
sway bars are not just for track use either
i run the Cusco 25mm rear sway bar w/Perrin endlinks set to the medium holes. i also use a Cusco OS rear strut tower bar & a RMR lower subframe brace. my car no longer has extreme understeer. i can get the car to slide out in a corner but only at WOT...
if you run a 27mm rear sway on the streets that is adjustable, you can leave it on the softest (equal to 25mm) setting, until you hit the track.
but even so, if you couple the rear sway with a front sway that is smaller than the rear, and also incorporate the right ride height with spring rates and so on, you wont get tire lift. There are ways to prevent tire lift and still have a very stiff ride with large sway bars. Other wise, race cars and F1 cars and other GT cars would all be 2 or 3 wheelin every corner. You just need to set up your suspension correctly.
Originally Posted by Tsurara
Anyone who runs a 27mm rear sway on the street is careless and doesn't have a clue about what they are doing. Cusco struts are worthless. I do hear ok things about the trunk V brace, though.
I disagree. You seriously want someone to go and spend 2k on a coilover setup when they arent even used to the stock suspension? You get sways FIRST and run the car until your skill level exceeds the stock suspension, THEN you get coilovers. Heck, I'd reccomend doing a few track days before getting a rear sway so you realize WHY you need it. I don't understand the mod syndrome some of you people have.
but even so, if you couple the rear sway with a front sway that is smaller, and also incorporate the right ride height with spring rates and so on, you wont get tire lift. There are ways to prevent tire lift and still have a very stiff ride with large sway bars. Other wise, race cars and F1 cars and other GT cars would all be 2 or 3 wheelin every corner. You just need to set up your suspension correctly.
Besides, why upgrade the front when you don't have to? The 25mm is going to sufffice for MOST skill levels up until you are having a prepped track car and running in national events, etc. Upgrading the front would just be a waste of cash that could be used on brake pads or something.
I might be going out on a limb here but if this guy is asking for validation on Cusco sways, I don't think he is going to really understand proper suspension setup. (No offense to the original poster)
i dont think that i shall be gettin the sway bars, seems that the stock ones are jus fine unless u wanna run a track and NEED the sways, im sure u could use them for street, but i think im jus gonna get a set Tein coilovers with the cusco strutbars and lower arm bars.....that should be fine i think
I don't necesairily agree with this. Running a 25mm on the street isn't always a good idea either.
well umm....Please inform me of how to set up suspension....
mostly street/ possibly a autox or 2......
If you are going to run autocross you are best off getting some nice tires and getting some practice. Buy a set of dedicated r-compound wheels that are stock size with some Hoosiers or whatever the autocross crowd uses and run in A-Stock until you get good. Beginners get eaten alive in street mod.
