Yokohama Advan A046- What tire stands up to it?
Originally Posted by Greg K
PS2's are great tires, but they do give up some grip on the A046's. I have 10k mile on my PS2's and they still have at least 50% life left. They have a softer sidewall and you can feel them "roll over" a bit in really hard cornering, but I can't complain. I upped my pressures to 39F-36R and have had nothing but good times.
My car is a daily driver and I don't get to push it often. How much of a difference in performance is there between the PS2 and 046?
Would you buy the PS2s again?
thx!
Originally Posted by value
Might also watch out for the new bridgestone RE-1, I think it's called? Coming out soon.
The Bridgestone Potenza RE-01R is going to be stateside next month (April) and will be an "ultra high performance tire"-- not competition as the "R" leads some to believe. Apparently the execs "liked the R" even though its not a comp. tire. It will be super sticky and only intended for dry, summer driving. It will be a great tire for the aggresive driver who doesn't want to change tires on autox day. I'll be getting a set hopefully mid summer. Treadware 140 so you can run in STU for autox . I'd say their specs are similar to the Yoko Advan Neova in terms of treadware and grip (only better ).
I recommend the Bridgestone Potenza RE050A Pole Position for daily driving with TONS of grip. I'd give the grip two thumbs waaaay up. Treadware 140. Compare these with the Michelen Pilot Sport PS2 (but better or course).
Happy shopping.
Go BRIDGESTONE!
Happy shopping.
Go BRIDGESTONE!
Happy shopping.
Go BRIDGESTONE!
Originally Posted by upstateEVO
Thanks Greg, that's good info. I saw one of your posts in another thread about the PS2s which was helpful.
thx!
thx!
I heard some good things about the Falken Azenis RT-615. They are about to release the 235 40 17 size for the EVO stock rim. Anybody use any of the larger sizes and what luck have you had with them? Again, how do they compare to the stock Advan A046 in terms of responsiveness?
235/40/17 is not ths stock evo size. I am currently street driving my RA1s to shave them down a little. I do miss the steering response of my advans. The RA1s more than make up for the loss of steering response w/ grip though. I will probably end up getting the Azeni 615s for my street tires eventually.
PS2's are dramatically different from the Advans. The side wall is so soft the Evo no longer wanders left and right depending on road surface. Stearing response is down, you can move wheel an inch or so before car turns. Road rattling is reduced. The tires have good grip and don't squeal. I hard cornering they have an un-nerving tendency to give sideways which makes for an unbalanced tip-over feel.
I think the PS2's were designed for large wheel 18" and 19" used on Euro cars. Probably and excellent choice for those with aftermarket wheels.
Do I like them? Heck yeah! Now I can drive to LA from OC without loosing my fillings. Great for daily driving. Treadwear looks good. Excellent on wet roads.
I was very impressed with the stock STi's Bridgestone RE070's, and you can get a set of take-offs for a great price over on Nasioc. Dare I say on an EVO forum that they have the hardest sidewall in the industry [in that size]?
i ran the ps2 on my 03 and when the stockers(ao46) on my IX wear out i,m going back to the ps2,s. excellent tire, great dry grip fantastic in the rain, nice and quiet compared to the advans. i highly recommend them to anyone. stock size 235x45x17
Check out the Yokohama Neova
I would consider myself a very spirited driver and this is also my daily driver.
They have unbelievable grip! I highly recomend them to anybody who wants the ultimate street tire.
I would 2nd the Michelin PS-2's, they are very light (22 lbs) and unless you are tracking
your vehicle, you should enjoy them far better for daily/spirited driving than the noisy
and uncomfortable stockers, they do feel light on there feet.
My first choice was the "Firestone Firehawk SZ 50 EP" since they gave me 25,000 miles
of (handling/looks/comfort/wear), the perfect tire, just stopped making them in Evo
sizes, and only about $150 each........oh well.........
Visit the UK Evo forums. The Advan is not E code or whatever it is so they cant buy them over there....so they are forced to buy other tires (tyres if you will) and have done plenty of research seeing they have had the Evo for a while to vs. US.
The Advan Neovas are a great tire but extremely expensive.
The Azenis RT-615 is a great tire but very reasonably priced. They also last a long time (for a high performance tire, anyway). I got about 20000 miles out of them and that included 50 autocross runs, about 15 passes at the drag strip, and alot of HARD street use.
EVOlutionary
EVOlutionary
