volk le28n offset?
volk le28n offset?
what would be a good offset for the le28n's in 18x9.5?
I wanna go w/ a 255 tire and am lowered w/ s-techs
a member on here has them in the 18x9.5 w/ front offset of +28 and rear of +34 but i guess thats a special order
what would a good common offset be for these rims? thanks alot guys
are you sure a 255 tire will fit on s-techs w/o rubbing?
9.5" seems awfully wide for that severe of a drop.
well, unless you're just doing straight line driving....
you might have to roll your fenders at the least.
i run 235/40/18 w/ s-techs and it's a tight fit...no rubbing luckily but still not much clearance.
18x9 +35 with 255 will work fine.
18x9.5 is too wide, even with 235's.
I have 18x9.5 +28 with 255(Front) and its rubs badly...I need the front fender cut in order to fit.
I have 18x9+35 with 255 (rear) and it definantly needs the rears to be rolled
2006evo
Apr 23, 2007 06:04 AM
d1_evo
May 1, 2004 04:50 PM
