problem with tein install please read!!!
Hey guys i installed my tein s techs today and for some odd reason i have a popping noise comign from the front drivers side spring area. We check it out and everything appeared to be fine. It doesnt do it all the time but it will every once in a while any help would be greatly appreciated
Matt
Matt
Originally Posted by VIIImylunch
it may not have seatted right
mine did the same thing untill we re adjusted the how the spring was seated.
After you re-seat the spring with the proper preload then everything should be fine.
Good luck
Fomer Vendor
Check the nut in that little cap thingy. What holds the strut to the whole, bucket, seat, spinny thing, where all the grease is. I had mine a little loose and it was making noise.
I installed hotchkis springs about 2 weeks ago and now i have a noise coming from the front right spring when I backup and turn the wheel. Its the spring moving around and im almost positive it needs to be reset. Can I just tighten the strut nut, or should i pull it all apart to reset?
Thanks for your time
Houston
Houston
Houston
Houston
After getting the spring/strut assembly out, I just used my impact wrench and tightened the top nut down which gave me the proper preload on the spring and i was set.
ight thanks for info, im going to pull strut assem tommorow and hit it with the impact a couple times. Im also going to make sure i didnt put the spring in upside down. I dont thinks its possible, but im going to check it anyway.
Thanks
Houston
Thanks
Houston
Not sure the front springs can be installed upside down, just did mine and they looked the same on both ends. I just installed with the writing right side up. The rear can be installed improperly..
I had to really mess with the fronts to get the springs in the correct position. I could see this being problematic...
One thing I noticed was there seemed to be no difference in left and right shocks in the front or the rear (obviously there is a difference between front and rear). Is this the case? I took care to place them back where they came just in case... Can they be switched universally?
Originally Posted by Makos1610
how to put this spring to get rid of that noise. How should they be seated?
This will get rid of the clunk.
WTT[MidWest]: Ams high flow cat test pipe for ets/ams test pipe
03redtype-s
Dec 26, 2016 07:49 AM
03redtype-s
May 29, 2009 11:02 PM
03redtype-s
20
Nov 18, 2008 01:43 AM
03redtype-s
Jul 7, 2008 05:08 AM
