Camber kit
Camber kit
Hey I just got back from an autocross day and I experienced considerable wear on the outsides of my front tires. I was considering a camber kit for better cornering and to reduce this type of wear. I found what I thought was a good deal on one here http://www.drivewire.com/Performanc...camberkits.html and I didn't know if anyone had tried them. Also I was wondering if it would be a big hassle to change them for track days and then back for regular driving. Any comments would be appreciated.
Link isn't working...
Wear on the outside edges is a sure sign you could use more negative camber. We've always had success with Cusco Camber plates...
As for changing them for track days and then back for regular driving...thats not entirely necessary. You can get away with a good amount of negative camber on the street just fine without excessive wear. Toe is what you need to worry about.
Someone always used to say to me:
"Camber decides where the tire wear occurs, toe decides how much it will wear."
- drew
- drew
here is that link again hopefully it works this time
http://www.drivewire.com/Performance...amberkits.html
- drew
- drew
Originally Posted by Bexa20
When you say that you has a success with the Cuscoo Camber plates do you mean on the stock suspension or the coilovers??
Originally Posted by gt_evo8
I was still curious if anyone had tried these becuase the are only $25 compaired to the cusco which are much much more expensive
Dave
JWERNER24
Oct 5, 2005 05:18 PM
FlashAngel
Sep 23, 2003 08:01 PM
