aerodynamics discussion in chassis engineering
Old Aug 23, 2006, 06:14 PM
  #61
SaabTuner's Avatar
Originally Posted by tvbf1
I idea of the airplane wing to create lift right. Like you said the distance on top of the wing is longer then the bottom which make the distance that the wind or air have to travel is longer in top then bottom which which causes a low pressure on the bottom inturns causes lift. Correct?
No, not quiiiite correct. NASA's Glenn Research Center has a good website on introductory aerodynamics with a special section devoted to dispelling that myth, as well as some others, about what actually generates lift.
This is the page dispelling that particular incorrect theory: http://www.grc.nasa.gov/WWW/K-12/airplane/wrong1.html
The page with the correct theory: http://www.grc.nasa.gov/WWW/K-12/airplane/right2.html
The simplest and most accurate way to think of it is that the airflow is turned. Because of the net initial vorticity created by the turning, this theory was effectively proven correct when Ludwig Prandtl was able to photograph the counter-rotating shed vortex, described here: http://www.grc.nasa.gov/WWW/K-12/airplane/shed.html
The aerodynamics index for the GRC has a lot of good pages, if anyone is interested in reading: http://www.grc.nasa.gov/WWW/K-12/airplane/short.html
-Adrian
Old Sep 6, 2006, 03:45 PM
  #62
chronohunter's Avatar
Originally Posted by Ludikraut
Do you guys have any info on fender louvers? You see them on most, if not all enclosed wheel racecars, but what is the benefit of going with a top mount louver (seen on some ALMS cars) versus one on the side (DTM)?
I also found this: "Race Car Aerodynamics: Designing for Speed (Engineering and Performance)" by Joseph Katz
l8r)
to simply evacuate air from the wheel well, the primary benefit is increased front grip by making the splitter more effective. there are secondary benefits as well such as brake cooling but the front grip thing is the real reason
it would depend on the car's particular areo package to determine which style is most useful it could also be a rules thing, generally speaking you want to pull as much air out from under the front of the car as possible after the splitter (unless you have a full underbody in which case a great percentage, but not all, is channeled all the way through to the rear diffuser). Changing the percentage allows the team to adjust the aero balance of the package.
Old Sep 6, 2006, 04:04 PM
  #63
Originally Posted by nothere
wasn't it ALFA ROMEO who won everything in the seventies with the underpants fans.
gotta' get me some of those (great on a summer day )
Old Sep 13, 2006, 02:10 AM
  #64
trinydex's Avatar
-Adrian
this is very good... so the turning of hte fluid then turns the wing which sort of acts as your hand under a broom stick (upright) type thing yeah?
Old Oct 27, 2006, 04:41 PM
  #65
RogueSTi's Avatar
wow...I really feel stupid now.
Old Nov 1, 2006, 07:44 AM
  #66
Fireball's Avatar
Ok, after reading most of this thread, I only really have one comment...
From testing MYSELF on the track, (Road America to be exact), I picked up 5-6mph on the top end without changing ANY other equipment in similar temperature environments just by adding the new APR rear diffuser... (135mph vs 140-141mph)
This proves that the "parachute" effect on an Evo is rather large. These values were datalogged and recorded, so it wasn't a glacing at the speedo/tach thing. Fixing this problem helps with drag on the top end.
Now, I can't say that it helped with any amount of "downward force" at all, it felt roughly the same through the high speed turns.
I will ALSO admit, that the Evo has the aerodynamics of a brick. I can be FASTER than the Corvettes in the turns, but they will pull on me in the straights if I am next to them. Now, if I'm in the draft, I can usually slingshot around them without any problems. I've topped out well past 145mph just by using one of their drafts.
So, how do we make the Evo slippery-ier? I am not too concerned about downforced, persay... you have to remember, most Evos are not going at crazy speeds where downforce is really needed, but more to help with speeds past 100mph.
Old Nov 1, 2006, 09:42 PM
  #67
trinydex's Avatar
data??? just cuz i figure others will ask.
Old Nov 2, 2006, 07:36 AM
  #68
version 2 beta's Avatar
This is an awesome thread.
Old Nov 14, 2006, 11:51 AM
  #69
GTWORX.com's Avatar
Interesting stuff...
What i would do to reduce drag? Your APR diffuser apparently works, and i'd add fender louvers, a decent front lip/splitter, lower side skirts, and some creative underbody panels. Might look funny, but there's not much else you can do.
A big front splitter would be tempting for a track car, and IMO would be worth the drag penalty, which wouldn't be too bad if designed correctly.
Tape up the seams on the front of your car too. Hood, headlights, fenders etc.
- Andrew
Old Nov 14, 2006, 04:31 PM
  #70
trinydex's Avatar
any data? i just wanna see some logs...
cudaman07
Mar 10, 2016 03:22 PM
eVoRox
Mar 30, 2015 08:19 PM
MoveOverRacing
EvoX 'For Sale' Exterior Styling
Nov 24, 2014 12:37 PM
EGbeater
Sep 16, 2011 10:06 PM
willitas34
Aug 9, 2010 12:28 AM
Quick Reply: aerodynamics discussion in chassis engineering
