Coilovers - Spring Rate Question
Old Jun 7, 2006 | 07:23 PM
  #31
Matt2.8NJ's Avatar
Originally Posted by EVO Nathan
Like I said in my first couple of posts, then car came with the Flexs on them. The point of the thread was not to determine, or get opinions on whether I plan on tracking the car from time to time or not.
The questions is what effects/benefits/setback/etc....will come about if I drop the spring rates down the from the current 12k/10k level to a 10k/8k level? What would the effects be both on the street and on the track?
Nathan
Oh, I should have made myself more clear. I meant I was agreeing with your original assumption that you would be better off (for your usage) with softer springs (closer to stock, which is why I brought in the stock suspension comparison).
Good luck with whatever you choose- please give us a report on how the Flex's feel with the softer springs.
If you decide to simply dump the Flex's, let me know
Old Jun 8, 2006 | 09:46 AM
  #32
EVO Nathan's Avatar
After I re-read your post, i sort of figured that is what you meant. I am in the process of ordering the springs now, but I have to wait for them. Nobody has them in stock at the moment. So, they need to be ordered from Tein direct.
I will be sure to update this post after I get the springs swapped out.
Thanks again for your comments / suggestions. And, if I decide to sell them I will let you know (which I have actually thought about).
Thanks,
Nathan
Old Jun 8, 2006 | 09:47 AM
  #33
EVO Nathan's Avatar
Originally Posted by kekek
Ok, this helps a bit. If you want a softer ride and are happy with the balance of the car now I would run the 10/8. If the car is too pushy for you then I would try the 10/10. I don't see the car bottoming or having any ill effects especially since you won't be on a very grippy tire (my assumption). If your not a very experienced driver I would shy way from high rear rates anyway as I could only see them getting you into more trouble. Just make sure you get a good alignment after swapping them and don't drop the car too low.
My advice applies more to an autox car, but I have friends running similar rates at the track with no ill effects.
HTH,
John
Good to hear. Thanks for your help. I will be sure to keep the 12k springs, just in case I think that the 8k setup will be too soft.
And, i will definitely get a good alignment after I get them installed.
Thanks again,
Nathan
Tri-Bar
371
Dec 14, 2015 06:22 AM
WeirdGuyXp
16
Dec 10, 2015 03:12 AM
imissmyhonda
16
Nov 13, 2015 06:56 PM
mrr5049
Aug 24, 2015 09:15 AM
DJ Brett B
17
Apr 4, 2008 09:23 AM
Quick Reply: Coilovers - Spring Rate Question
