Excessive Tire Wear (inside front)
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
At first I thought camber, but the car is completely stock so negative camber should not be the issue. I called Mitsubishi and Yoko and addressed the issue with them. Mitsubishi Parts Manager claimed he never heard of a problem with tire wear, so I basically discounted him. Yoko rep. told me to go to an authorized Yoko dealer (e.g. NTB, not Mitsu dealer) and they would warranty it if there was not an alignment issue
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Do you guys know what is going on here? What causes the inside 1" to wear but the rest of the tire to be great? Also, a friend on this site had his front inside blow at ~12,000 miles. Thanks
simply said, thats it. Probably just a bit of toe in.
I had this problem, took it to the dealer, they checked the alignment, and told me everything was fine! So when the wear got pretty bad at about 12k, I flipped 'em.
Zero toe at the front is a good setting, but your car more than likely does not have zero toe. I've taken my car to one alignment shop, had an alignment, and then took it to another shop the same day and had the alignment rechecked only to find that the alignment values from the second alignment rack were quite different than the first. So, I recommend checking the toe again. Like WP said, bad toe will rapidly wear the inside or outside of a tire much more than camber will.
the evo's camber is just set that way. wear on the inside of the tires is goin to happen. how often do you do highway driving?? thats is a big factor in its self. i had the same issue and about flipped. my alignment was checked a barely off. now where enough to cause this wear. just the way it is and price for soft tires that handle great. another reason why some ppl sacrifice some performance for tread life. this doesn't occur on the harder rubber as bad. chances are, you will not get assistance in getting new tires. if you do, CONGRATS!!! first i heard of.
that is normal. I noticed that with my O5 EVO around 6k miles. So I rotated them. Fronts straight to back. That's stock camber. Nothing to worry about. You just have to start hitting the corners a little harder. Remember, in Japan they have lots of Windee roads out there.
I've got 54,500 miles on my '03 VIII, and it's never seen an alignment. Still drives straight as an arrow, but I've got cupping on all 4 tires and I rotate them every oil change. I have the S-03s and the treadwear is getting down there as this is their 3rd summer season. Would this be a toe issue too?
