Installed Rollbar- car understeers now
The Autopower is clearly made for the wide array of potential drivers. I am short and sit upright, the Autopower is too far back in my opinion. There is a good 10-12 inches from the harness bar to the seat back. I honestly wish I had gone custom...
I am going to VIR for the NASA North Course event this upcoming weekend. I need to see how it does there with the Hoosiers.
Originally Posted by nukblazi
I was mostly curious if anyone removed the front strut tower bar or installed a lower subframe brace up front. Basically, a sanity check plus attempt to resolve. Tire pressure did it.
Thanks
Thanks
I was just running through possible changes; if the car was too stiff, it is a way to reduce stiffness.
I've received several suggestions regarding the removal or lack of need of the front strut bar from people who track the evo.
Robi also mentioned to me about the front tower bar, or lack there of. I'm still running the stock one though, but it's not bolted in the center (camber plates raise it up)
I balanced it out with tire pressures. I think it was a combo of new tires and additional weight. I did donuts in both directions, wore down the tires a bit and adjusted the pressures. Seems balanced now. I'll see for sure this weekend at VIR. I almost got nailed by the fuzz playing with the oversteer around town... not good.
WTB[Northeast]: WTB uicp
Illrunya
May 18, 2016 01:10 PM
