Squeal/howl when making left turns
Lately, I've been hearing my car (specifically the front) make a squealing/howling noise when I make a low speed left turn, like coming into a parking spot. It's almost exactly like a low brake pad noise, but not as high pitch. My brake pads are probably running out right now, but the noise still happens when I don't even use the brake. Can you guys throw some suggestions to me as to what it may be, before I have time to take it to the shop? Thanks.
The 03 I belive are shimmed improperly from the factory but they will noe tell you that. I am going through the same thing they are blameing it on me and my driving took it to a shop had them look at my TC and he said the wear on the ring and pinion are due to improper shimming. I would say it is the TC going out and belive me it is going to be expensive unless your lucky enough to get a good dealer that will warranty. Good luck
manray
Sep 17, 2016 10:47 PM
Go_Lancer_Go
Apr 5, 2009 11:46 AM
Thwack
Jul 20, 2004 06:30 PM
HwangTKD
Aug 5, 2003 08:21 AM
