Has Anyone Boiled the Stock Brake Fluid?
Perhaps you didn't notice that there are two bleeder valves per caliper. It's a bit more inconvenient to bleed the inner valve with the wheel mounted!
It's always a good idea to bleed/replace the brake fluid before a track event. I'm not sure of the boiling point of the stock fluid, but it is really irrelevant. You should have fresh, dry fluid in at the beginning of each track event. Ford dealers sell a pretty good Ford-branded high performance fluid quite cheaply. It has a dry BP of 550F.
I know this is an old thread, but I found it while searching for brake fluid testimonials.
Anyway, I just wanted to add that it isn't difficult to boil the EVO brakes on the street if you drive aggressively. I managed to do so this weekend on a canyon drive. I was chasing down another member of the group in an STi. His brakes held up fine, but about 4/5 of the way down the canyon my pedal was on the floor and I had to back off. I like to trail brake a lot to set up the attitude of the car, so I know that driving style is a factor (the STi driver said he just likes to quickly 'jab' at the brakes).
Anyway, looks like the factory EVO fluid is not up to the job, so after just 2,000 miles on the car I'm looking to replace it. However, I do not want fluid that I'm going to have to change every couple of months, so I'm a bit leery of running RBF600.
-Pace
-Pace
