18x9.5 (+38) 275/35/18's allowable clearance?
18x9.5 (+38) 275/35/18's Minimum allowable clearance?
I test fitted a set of RP01's today. Im still on stock suspension, the wheels fit perfect without any touching or rubbing. I noticed on the rear, the tires were about 5mm away from touching the rear control arm. In the front, the tires were about 4mm away from the inside strut. Are these clearances sufficient for any sort of aggressive driving?
I'm running the work emotions in that same offset, 18 X 9.5 and 275s. I only get rubbing when I drive the car really hard. No metal rubbing, just a little rub on the plastic. They barely clear the calipers, probably 2-3mm of clearance. I'm running Bilstein coils.
I actually weighed them against my BBS MR's. The 17" BBS weighed in at 44.4lbs with tires. My RP01 weighed in at 49.2lbs with tires. All of them have equal % of tread, but i do know that different tire brands weigh more than others. either weigh i think a gain of 5 lbs for wider tires, is a decent trade off.
evil03
1180
Sep 21, 2021 10:31 PM
smgevo
108
Mar 13, 2018 08:45 PM
Russco
Sep 10, 2010 03:47 AM
