Rota D2 Wheels
Rota D2 Wheels
I am considering getting these wheels in 17x8.5+25 and am curious if they will fit? Also will I be able to put them on stock tires? Thanks
Here is the link
http://store.racinglab.com/rowhd21754.html
Here is the link
well in stead of a different offset...you could maybe try a spacer.
with my 18x9.5 et27 im running a 12mm spacer in the front...
BUMP for subydude's answer!
I am running Enkei NT03+M 18x9.5, I am however running staggered fitment, running et27(f) and et40(r). I am running a 12mm spacer (f) and a 5mm spacer (r). The spacers will NOT affect your driveability, if anything it will help improve your handling because it will push the wheels out giving your car/evo a wider base.!!
Spacers will not help make the wheels fit. The issue isn't with the spokes hitting the caliper, it is the overall diameter of the inside portion of the wheel that does not clear the caliper. Even the 18" D2's didn't clear brembo's in subaru fitments. I believe Subydude is coming out with some new sizes to work so PM.
darkmitsu
Apr 26, 2008 10:36 AM
atilla
12
Jul 11, 2006 07:42 PM
Zippo41189
For Sale - Wheels / Tires
Jun 25, 2006 03:42 PM
