255/40/17s clear Ohlins?
Quick question for you suspension guys..
I've got the 5zigen FN01R-C 17x9et35 with 255/40-17 RA1s. I'm looking at getting the Ohlins FLAG suspension and wnated to find out if these wheels/tires would clear the coilovers without spacers?
Thanks
Thanks
Well, i was unsure how low the spring runs on the front. The wheels barely clear the front bilsteins and if the springs on the coilovers run lower it could be an issue..
I realize that, but if the spring perch comes below where the stock perch ends, then that will put it beside the tire. As i only have 1/4" of clearance between the tire/shock-body as it is, if the spring perch comes down below the position of the stocdk mount i'm screwed..
We run the same wheel/tire combo on the WORKS Time Attack EVO with the WORKS/Ohlins Stage IV setup. We do use a spacer up front, but have done several other cars with the same/similar package as well without them.
I have the Flag L (Works stage IV) and the exact same wheels and tires you are asking about, I needed a 5mm spacer to keep the tire from rubbing on the springs, but only on the front. I highly recommend extended wheel studs whenever you use a spacer.
I have that rim/tire combo with the Vishnu Ohlins set-up. I had interference problems if the front camber bolts are set to maximum camber. You can do two things to reduce the interference - remove the helper springs or change the position of the camber bolts to give minimum camber and adjust camber using camber plates. I did the latter. This seems to work OK, although my camber plates are maxed out on one side at -2.5 degrees.
In hindsight, the better solution is to keep the bolts maxed and remove the helper springs to give the clearance. This will give more adjustment range in the plates.
tmaddox
15
Oct 14, 2013 12:22 AM
TK40
15
Jan 16, 2010 09:53 AM
slaythoven
16
Jul 18, 2009 08:41 PM
93civEJ1
30
Oct 23, 2005 10:14 PM
