20mm and 5mm Spacers
I need a set of 20mm front and 5mm rear. I prefer the non-bolt on type and I have 52mm studs.
I've searched the forum's vendors but can't find any.
Where can I find these?
Thanks
Thanks
I got the good stuff (hubcentric) from:
Options Auto Salon
www.optionsauto.com
1-800-OPT-AUTO(678-2886)
HR10656715 SPACER: MITSUBISHI 5mm - 5:114.3/67.1
I believe Turner also has the nice H&R racing 5mm kit that I bought. The kit does come with 5mm longer studs, but you can choose not to install them and use the spacers only.
www.turnermotorsport.com
Options Auto Salon
www.optionsauto.com
You can have a set custom made to your specs for around $100 shipped.
http://wheeladapter.com/home.asp
Options Auto Salon
www.optionsauto.com
Options Auto Salon
www.optionsauto.com
EVOlutionary
For those of you who might have occasional seizing problems with lug nuts from high heat braking track days, you'll be interested in this part number for your H&R Springs Trak+ 5mm spacer kit:
Part # HR1253554 - replacement studs for the kit. I've cooked 2 studs during a 2 day session at Watkins Glen, so I'm assuming these H&R studs may have the same risk. Probably time for a brake duct kit.
You can also get these too,they are made by Kics in Japan. Options Auto Salon sells them along with the H & R ones along with A-Spec,Evasive and other people that buy Volk directly from Mackin Industries.
http://www.mackinindustries.com/wm/k...eadspacer.html
maxroach
Jul 25, 2019 03:47 AM
dubbleugly01
Jun 30, 2007 09:49 PM
