Rear Big Brake Kit ?
That's a very complex question. "Worth it"...how much will it cost you? Why are you considering it - Performance? Asthetics? I assume you have upgraded the front brakes? Are you honestly skilled enough to handle the rear end stepping out while trail-braking into a turn?
you really do need to specify. going to this brembo kit in the rear will really prove to be minimally beneficial, even for a car that is tracked very often. A good set of pads and rotors will show the same improvement on the rears. Correct me if i'm wrong people but just because you upgrade the rears to bigger calipers and rotors doesnt mean the brake bias of the car changes so I dont even think this kit would affect trail braking upon corner entry. The only real positive I could this to using a kit like this would be after you upgraded the fronts because you have fade issues. then experiencing the rears fading and causing problems on corner entry. I'm still fairly certain a good set of pads and rotors would fix this problem. As was said above all these issues require a very skilled driver to notice any change.
butttt. i have a feeling you want these for the bigger calipers
Stock Sucks! I have not been very impressed with the Evo brakes. If I have one gripe about the evo it's the brakes. And yes I track my car often and have tried several brake pads and rotor combos. I will be upgradeing mine front and rear.
Weight savings is good.
Pedal feel and control improve.
(especially if you are a more skilled driver; trailbraking, left foot braking, driving the car with your feet rather than your hands)
Some of the above responses are correct in the fact that it is not a "necessity" type upgrade. It's like the difference between 350whp and 400whp. If you can find places or situations to use it, it will be money well spent.
Whether one needs a rear BBK is separate from whether one wants it =)
Regardless, RacingBrake makes a nice rear kit:
http://www.racingbrake.com/EVO_8_REA...34-311-411.htm
They also make rear 2-pc rotors:
http://www.racingbrake.com/EVO_8_REA...p/2043-311.htm
Personally, I use the 332x28 front BBK and it cools better than stock, weighs 10lbs per front corner less, and shifts the brake bias about 7% to the rear to more effective use the rear brakes.
For all those who think the stock brakes stink we had them on the 640whp AMS Time Attack car that I was lucky enough to drive to a class victory and 2nd overall at the last Redline event. It was the fastest an EVO has ever gone around that track (and it is a hard braking track). We had Girodisc front and rear two-piece rotors PFC pads and Castrol SRX fluid with the stock calipers.
Lesson here; the stock calipers are much better than many aftermarket calipers (heck we took of name brand aftermarket stuff after problems). Put on proper pads, fluids, ss lines and bleed them well, and you will be impressed. Put on that exact combination and you won't be wanting for brakes I promise you!
They may not have the bling factor of massive brakes but the people I drive for prefer trophies (and they're even shinier).
