alignment specs please
Old Jan 20, 2007 | 03:23 PM
heavens turbo's Avatar
i know, i know, the advans don't last, i am getting new tires, (19,000 on fronts), i was just wondering if anyone would have access to the stock alignment specs for an 05 8 gsr, all stock. i'm a mechanic and i don't want to spend the money for an alignment with a perfectly good alignment machine at the shop. searching did not produce much. love the advans but i gotta go with les schwab . thanks in advance for any replies or flaming.
Old Jan 20, 2007 | 03:37 PM
mathgeek's Avatar
I went to the dealership and they printed them out for me. And I only got 16,000 miles out of my Advans. It turns out that the toe was way off from the factory. I have a neutral alignment now which makes for longer tire life but less exciting handling.
Old Jan 20, 2007 | 03:43 PM
19psi's Avatar
search "stock alignment".
You'll get about 10 pages.
Old Jan 20, 2007 | 03:46 PM
EVO X Owner-2-B's Avatar
Search tab > Advanced search (in blue, at the bottom) > type "stock alignment" > drop down arrow and select search titles only ... simple as that.
https://www.evolutionm.net/forums/sh...tock+alignment
Took me all but 2 minutes tops. You wrote, "searching did not produce much." Well, with all due respect, learn how to search better.
Old Jan 20, 2007 | 04:22 PM
thanks guys, i typed stock align and got hella unrelated posts with "alignment" in there. thanks for the help and thanks evo X owner for being such a helpful ****.
Old Jan 20, 2007 | 04:32 PM
19psi's Avatar
I just searched and came up with this stock specs.
Front camber -1 or -2 deg
Front toe 0 to + 2mm
Rear camber -1 deg
Rear toe in 0 to -3mm.
Hope this helps.
Old Jan 20, 2007 | 04:35 PM
gsrboi80's Avatar
I run front and rear toe at 0.
1.5- up front and 1.3- in the rear
Old Jan 20, 2007 | 04:37 PM
thanks guys, if i didnt thank you already.
AMF
Mar 25, 2010 05:16 PM
heSOshAdy
20
Jul 27, 2008 04:31 PM
s2KMR
26
Mar 29, 2007 08:35 PM
sanjaya1
Nov 5, 2006 10:22 AM
Ludikraut
15
Aug 3, 2006 02:02 PM
Quick Reply: alignment specs please
