TEIN Mono Flex -- Feedback
Old Feb 18, 2007 | 11:17 PM
genrec's Avatar
I did a search and some reading and came with some old posts with pretty much no information other than they were coming to the US sometime middle of last year.
Is anyone now currently running these and what is your feedback? I'm not talking the regular flex but the MONO flex.
Thanks
Old May 3, 2007 | 07:12 PM
fugiwara's Avatar
yes I am interested on this too
Old May 3, 2007 | 07:16 PM
fugiwara's Avatar
up
Old May 4, 2007 | 10:31 AM
RichiW's Avatar
In have the Tein Mono Flex, i was the first guy in the UK to get it
Its been on the car now since the middle of last year, its very good for track work and on smooth roads, but on back roads its simply too stiff, even on the softest setting. The ABS locks the brakes and the car bounces around corners, making it quite a dangerous drive, although your back roads might not be as bumpy as we have here in the UK
Old May 4, 2007 | 10:34 AM
RichiW's Avatar
oh yeah, make sure you get some extension bars on the 'C' spanners and really tighten them up well, i had a front coil start to unwind itself, and i've heard it happen to other people too with the earlier normal 'Flex' suspension.
I'd give it 8/10 for track use and smooth raod use, 1/10 for back roads.
Old May 4, 2007 | 04:42 PM
fugiwara's Avatar
thanks Richi, well first time I saw the spring rate I was quite shocked, 14/10, thats too much for street. so how bad is your back roads over there?
Old May 16, 2007 | 08:30 AM
pternstrom's Avatar
For the european market they are springed with 9/7. I have tested these (mono flex) on track driving conditions and they worked well. Im still going to get stiffer springs (12/9?) for them to see if I can get even better results.
Old May 16, 2007 | 01:36 PM
RallySport Direct's Avatar
Silver Sponsor
We have run the Mono flex on the Subarus here we have not had a chance to get them on a evo yet. All the evos here already have super racings.
We have seen a nice increase in performance over the standard flex. I would say these are the prefect bet for the weekend track warrior that has to go to the grocery store on the way home.
Old Jun 5, 2007 | 12:15 PM
fugiwara's Avatar
is the spring rate really 14/10? hows the over all driving impression on the public roads?
i heard the valving is really good.
Old Jun 5, 2007 | 12:20 PM
Silver Sponsor
Yes the EVO rates are 14/10
The subaru rates are 10/7
The 14/10 should make for a really flat handling front end without the need of upgrading the front sway bar. I could not give you any insight into the comfort of them on the street.
The valving on the subaru is very nice.
Old Jun 5, 2007 | 12:24 PM
Warrtalon's Avatar
My Ohlin setup has 12kg/16kg springs, and I drive my car daily. Don't let 10/14 scare you.
Old Jun 5, 2007 | 12:29 PM
fugiwara's Avatar
thanks for the feedback guys. oh by the way, I notice the ohlins setup you have has stiffer spring in the back, and most other C/O have stiffer spring rate in the front, what is the benefit of having stiffer rate in rear like stock setup?
Old Jun 5, 2007 | 12:30 PM
Silver Sponsor
12F/16R or 16F/12R
teins are 14F/10R
just for clarification
Old Jun 5, 2007 | 12:31 PM
BLKLIST's Avatar
I have these installed on my lightly modded IX for about a month now and I really enjoy them not only as an agressive daily driver but also on the track (drag and road course) Adjusting the dampening from underneath the front struts isn't that convenient but easy enough without jacking up the car. I've ran teins on my SRT-4 and a RSX-S for awhile and these are the best yet and compliment this car.
fugiwara's Avatar
Can I reverse the spring rate 10F/14R? or choose any other spring rate? what would you suggest?
Quick Reply: TEIN Mono Flex -- Feedback
