what else is left?
what else is left?
so i have my evo IX MR muellerized with JIC coilovers, urethane trailing arm bushings and 25mm adj rear sway bar .
what other suspension / chassis mods can i do that will actually make a noticable difference for canyon carving and track days ...
My suggestion is that you worry less about adding more frivolous mods and actually go out and learn to drive what you already have. You've already spent a lot of money on some nice stuff, but are you already an expert driver? Did you learn to maximize the stock suspension before doing all of this? If so, then have you gone and learned to maximize the new suspension? It takes quite a while to master it, and then once you've mastered, you'll already know what you need to improve it and won't have to ask this question...
