Track Rotor advice (replacing stocks)
I honestly can't see you getting pad fade and boiling fluid during an auto-x. Those are reasons to upgrade rotors. On a track, you need to dissappate the heat, i'd imagine you want to keep the rotors as hot as you can during the 40 second run, right?
They're just normal wear cracks, they're not even affecting normal braking right now with the stock pads... My race pads are about 30x grippier than the HPs (note: over-exaggeration), and they're slicks, not R-compounds.
So with two-piecers they're like 700 for the front pair and then only like 200 for the set to replace the part that will need replacing in the future? Are they better with heat than the stockers? Any advice from the track ******, Robi etc?
the pf 2 piece are like 600 and like 550-560 for the replacement rotor part. thats where i'm saying get the whole assembly, rather than the pieces.
I don't want to spend 500+ on replacements... Replacing pads and other maitenence is already enough. That's what I'm saying. Unless the 1100 dollars I spend on two-piecers will last me 5+ years of track racing with GT Spec brake pads (turn-your-rotors-orange-from-heat pads and view-lots-of-smoke-if-you-stop-without-cooling-down pads).
When i say events, i'm talking 200-250 miles of HARD track driving. Robi, or anybody that attends florida events will back that one up
I'd say the wear rate is phenomenal, honestly.
I'm with Mayhem on this one. I've used stock rotors from the beginning, only changing to something different this year becuse I'm getting help. I'll be running DBA 1 piece rotors this year, along with Ti shims and modified dust shields. Cooling is the biggest factor for sure, and I had plenty of problems last year dealing with the heat. A duct kit is probably the best idea, but I'm pretty low buck too, so I'm using the stock air guides as well.
Chris - you racing the e30?? Shoot me a PM!
So the verdict sounds like ducting and some of the stock-like rotors. Now I just need to find replacements for the stock rotors that aren't slotted or drilled... Sigh. STikiller.com had some but they don't appear to have them anymore.
These see ~100-200 hard track miles every weekend that there's an event (so, roughly every other weekend from March to October). The Z06s and Porsches will back that up Gotta get past em somehow.
http://www.rallysportdirect.com/shop...rs-p-2507.html
Those, for example. And 500 is still pretty expensive, but we can't all have s2000s with replacement rotors costing 50 bucks a piece I guess...
The only ones I ever found that weren't OEM, were offered by Evobrakes. I've Pm'd the guy back & forth a few times and he seems like the type of vendor we should all be dealing with and not the kind that likes to blow smoke and inflated prices.
