Having trouble removing OEM brake lines
I am trying to install some SS brake lines on my EVO VIII MR and cannot find the right size wrench to get the OEM one off. The banjo bolt on the caliper is not the problem, its the bolt on the other end. A 10mm is too big and a 9mm is too small, what gives? I even tried standard sizes with no luck. Is there something I am missing here? Is there such thing as a 9.5mm wrench or am I just retarted? Any help would be appreciated. Thanks.
The fittings are made of soft metal so that they will deform and seal. It is difficult to get them loose without rounding corners no matter the wrench used. So, I use a tiny pipe wrench. The fittings don't look pretty when you are finished but the pipe wrench works.
EGbeater
Jan 16, 2016 04:14 PM
urbanknight
37
Dec 26, 2011 01:35 PM
airlinevomitbag
Lancer How Tos / Installations
May 1, 2003 02:49 PM
