F/R Spring rate combo
When reading the spring rate charts, I noticed some setups are the same rates in the front and back, some are stiffer in the front than back, and a few are stiffer in the back than front.
What are the advantages and disvantages of all 3 setups in an AWD car?
It has to do with the desired wheel rate and the desired handling of the car. The EVO in stock form has softer springs in the front and stiffer springs in the rear, BUT it has a bigger sway bar in the front and smaller sway bar in the rear. The rates are tuned to get the desired handling and balance. An STi for eg: has stiffer springs in the front and softer springs in the rear, BUT it has a smaller sway bar in the front and bigger sway bar in the rear (I think) to get the desire balance.
Springs/coilovers setups that are of either equal rates on both front and rears or stiffer springs in the front and softer springs in the rear usually require a larger rear sway bar to balance out the wheel rates front to rear. Suspension is all about balance and compromise, and no one is really better than the other, they are just different theories and solutions to the same problem. Hope that helps answer your question ...
okay, I'm beginning to understand. Here's the scenario...
Stock evo understeers at the limit. Stock spring rates are 3.2/4
So if I want to car feel more neutral, I should consider just buying a thicker rear sway bar?
What if I decide to up my rates with new coilovers to say 10/10. To balance this out, would I need even thicker sway bar than example #1?
thanks.
thanks.
thanks.
thanks.
Swaybars and springs do not replace each others' functions in a suspension system. You should not be "making up" for soft spring rates using swaybars to stiffen one end, and vice versa you shouldn't be just jacking up spring rates to reduce roll.
Going too stiff with the swaybar (to compensate for lower rates) can reduce the effectiveness of an independent suspension, and not allow the shocks and springs to perform their functions effectively. Going super stiff on rates so that you don't need to run a big bar is not a viable option for street cars, because the ride will be uncomfortably harsh.
Generally, to combat understeer, you stiffen the rear end. Depending on how much understeer you're facing, this may call for just a more aggressive rear bar, or an overhaul of the suspension. The Evo's perform pretty well at the track with stock suspension, so make sure you're not just overdriving the car before you start dropping a bunch of money into suspension upgrades.
GTWORX.com
402
Dec 17, 2018 11:31 AM
jzsoarer
May 8, 2017 10:46 AM
ErikB
Aug 11, 2010 11:29 AM
chmodlf
37
Oct 13, 2009 10:57 PM
Wangracing
May 3, 2006 03:39 AM
