Camber plate and aligment question
Old Apr 9, 2007, 01:41 PM
  #46
kekek's Avatar
If your rear toe is in inches you will get excessive rear tire wear. 1/4" total toe is ALOT whether it be in or out.
Why couldn't he balance your front camber?
Old Apr 9, 2007, 01:44 PM
  #47
Czubaka's Avatar
Hard to get the camber perfect?! I could understand that if it was off by 0.1 deg, but off by 0.7 is rediculous! The car already has camber bolts, they're the two-position offset type.
Where are you located? Maybe someone in your area can direct you to an alignment place that actually gives a crap about the quality of their work.
Old Apr 9, 2007, 01:54 PM
  #48
Profoxcg's Avatar
Im in the miami / ft lauderdale area.
