Dunlop Direzza Sport Z1
#33
The Z1's don't understeer as much as the RE-01Rs. The Bridgestones tend to push more than Neovas also.
The tire seems responsive and firm. I took some at the limit corners and there was very little roll over. At first I thought the pressures were too high, but they were 34-32psi. Didn't even rub the outer block nubs off. Could be a durable track tire that won't chunk the outside edges. With the heavy mold release it's too early to say how much grip they have.
#36
I've heard that Dunlop tires have historically had "cupping" problems. This tire is supposedly built by sumitomo for dunlop. I'm dying here because I have to buy tires in the next month. I'm between the re-01r and the z1....any info on the wear or issues on the z1 would be greatly appreciaited.
Thanks
Thanks
#38
Thanks
Thanks
#40
Thanks
Thanks
You have an issue with picking between those two?
Open you wallet and ask it....
I would do the Z1 just to see how it is. Hell of a lot cheaper. I mean if the grip was less by 5% its worth it. It has to be a great tire and comparable to stock and the RT-615's.. A lot of folks on here said get the RT615's when I needed new tires and they are great. I am going to try the z1's next just because.
