rotating advans
rotating advans
I'm getting ready to put my advans back on for the summer. I used them last year for 7k without rotating them.
My question is this: Should I simply move the rear to the front, and keep them on the same side that they were on before. Since the tires are off the rims I thought maybe I'd get a little more use if I switch sides as well.
In other word:
left-rear switch with left-front
right-rear switch with right-front
OR
left-rear switch with right-front
right-rear switch with left-front
In other word:
OR
I don't think you are quite understanding what we are talking about. The stock alignment settings on the Evo will premeturly wear the inside of each tire. If you want the most use out of the tires you need to dismount them and swap them to the other side of the car. Therefore putting the worn section on the outside of each tire.
Now I have a headache...
wluc12
Apr 2, 2017 11:22 AM
Neal@tirerack
Feb 9, 2008 07:15 AM
High_PSI
Sep 15, 2007 09:31 PM
