HELP! Powder coat brembo failure!
not at even close to the feedback i was looking for. but thanks for the idea? duct tape didnt do its job because the inside of the pistons are pitted and the surfaces that had zero tolerance, the matting side is completly pitted and blasted. 3 out of 8 surfaces had overspary around the edges the othe 5 were completley blasted.
Ok...so take a straight edge across the mating surface and check if the surface is still flat. A piece of glass works best for this. As long as the surface is completely flat you should be ok. I have refinished a few calipers now and I dont break them down completely. It's not necessary. A high quality clear coat like Dupont's Chroma Clear will outlast the car!
Daitonsralliart
27
Aug 17, 2019 10:19 PM
WickedWhtMR
167
Mar 12, 2016 04:26 PM
