Espelir GT spring install questions!!!!! HELP!
I just installed my Espelir GT springs. Last night I did the fronts, and this morning I rolled the rear fenders and installed the rear springs.
The fronts went fine, had them done in about an hour. The rears went fine also, but on the rears I had to mount the spring with the "espelir" emblem upside down in order to fit properly. So now I am questioning the front! Does the "espelir" stamp go right side up or upside down in the front???
I have the front back apart, and my thinking is that the "espelir" stamp goes right side up in the front. Feedback anyone so I can get her back on the road???
umm....
i think we do.
we only have the fronts inverted, wheres STIs have all 4.
Articlefrom Automobile magazine:
"The Evolution uses the same basic suspension layout as the Lancer, with a strut-type front end and a multi-link rear, but it shares few actual pieces. Up front, there's a strut-tower cross-brace to stiffen the mounting points. There are larger-diameter, gas-charged inverted struts, forged aluminum lower control arms and front knuckles (in place of steel), a lower-control-arm connecting bar, and a 0.9-inch-diameter anti-roll bar. The power-assisted rack-and-pinion steering has a quicker 13:1 ratio. The track is wider than a regular Lancer's, too."
LINK:
http://www.automobilemag.com/reviews...itsubishi_evo/
Edmunds specs:
Model Year: 2006
Make: Mitsubishi
Model: Lancer Evolution
Style: IX
Base Price: $31,994
Price as Tested: $35,114
Drive Type: AWD
Transmission Type: 5-speed-manual
Displacement (liters): 2.0
Engine Type: turbocharged inline four
Horsepower (hp @ rpm): 286 @ 6,500
Torque (ft-lb @ rpm): 289 @ 3,500
Braking System: Four-wheel ventilated disc
Steering System: Power rack and pinion
Suspension Type (front): MacPherson inverted strut w/ stabilizer bar & strut tower brace
Suspension Type (rear): Multilink wishbone w/ stabilizer bar
LINK:
http://www.edmunds.com/insideline/do...6/pageId=68445
i think we do.
LINK:
Edmunds specs:
Model Year: 2006
Make: Mitsubishi
Style: IX
Base Price: $31,994
Drive Type: AWD
LINK:
and u drive an STI??
Model Year: 2006
Make: Subaru
Model: Impreza WRX STI
Style: w/ Gold-Painted Wheels
Base Price: $32,995
Price as Tested: $32,995
Drive Type: AWD
Transmission Type: 6-speed manual
Displacement (liters): 2.5
Engine Type: turbocharged, horizontally-opposed four-cylinder
Horsepower (hp @ rpm): 300 @ 6,000
Torque (ft-lb @ rpm): 300 @ 4,000
Braking System: four-wheel ventilated disc
Steering System: power rack and pinion
Suspension Type (front): MacPherson inverted struts w/ stabilizer bar
Suspension Type (rear): MacPherson inverted struts w/ stabilizer bar
Model Year: 2006
Make: Subaru
Base Price: $32,995
Drive Type: AWD
just did mine this weekend and noticed the same....but the springs wont go in any other way so i figured it was right....good to know that everybody is the same way., the ride seems stiffer., almost feels like when i first drove the evo.
thats weird, i had to install both of mine with the name upside down because the front springs wouldnt sit flush in unless it was upside down..and the back was also upside down..by the way do you guys have any clunking sounds? and also did u guys cut the bumpstops?
