Rolling Fenders?
Take one Evo+heat gun+1 baseball bat (wooden). The heat gun is used to soften the paint a little to prevent (or at least minimize) paint cracking. Work the inner flange surface of the fender back and forth using the tire as a fulcrum. Use a floorjack to add 'just' the right amount of fender/tire clearance for the bat to wedge in there. If there is some paint cracking use a touch-up brush to cover exposed ares.
With a little patience it's easy.
I also would like to know a good place to have this done professionally in the PA/MD/WV area.
I am going to just take it where I had the custom work on my previous rx8. Its in Chapmanville, WV. I think it would be a silly drive from the guy from PA though.
Any custom paint shop should be able to do this as I have found out.
Well I only live about 30mins from the WV border so I thought I'd throw that out there. There is a place literally 2 blocks from my place, G-Force Design Concepts, that has had numerous cars in Hot Rod Magazine over the years and I am sure they can handle this no problem...if they dont mind working on am import that is.
Oh come on. It's an Evo, not the Hope Diamond. Besides, what do you think the body shop is going to do differently (besides charge you $200.00 for the work)?
http://www.nengun.com/nengun/fender-roller
if you have a couple of friends that want to rent it for a dollars or ten, It might be worth it.
if you know how to put the wheels on the car you should not have bigger problems doing it, speak with letMeIn about renting the tool. We did two cars in one afternoon it not that difficult.
