Corner balance question
Old Jun 4, 2007 | 11:51 PM
Evo_Jay's Avatar
So i got some coilovers, and am using some scales tomorrow. This is my question. I have read that you have to disconnect the sway bars. Is this true??
Also any procedures, tips or advice would be great.
Old Jun 5, 2007 | 07:28 AM
LDOGGYDIZZLE's Avatar
Yes, you should, but it defeats the purpose if you dont have adjustable endlinks. Because once you perfectly corner balance the car, you'll then realize the holes in the bars dont line up with the endlinks. One you force them to line up, this preloads the bar and will screw up all of your hard earned corner weights.
If you do have adjustable endlinks, adjust them so the bolt can be installed by hand so the bar has no preload and no effect on your corner weights.
Also, check out this thread:
https://www.evolutionm.net/forums/sh...d.php?t=242031
Old Jun 5, 2007 | 01:21 PM
Evo_Jay's Avatar
I just have the stock sway bar and endlink, so what should i do?
Old Jun 5, 2007 | 01:27 PM
kingman4's Avatar
get some perrin endlinks. A littled more than $100 shipped.
(I heard of someone's Agency Power end links snapping on them... )
Old Jun 5, 2007 | 01:57 PM
With non-adjustable endlinks, dont disconnect them, go straight to corner weights.
Make sure you have 1/2 tank and you are in the car for corner weights.
AND MAKE SURE ALL OF YOUR TIRES ARE AIRED UP TO HOT PSI!!!! At least 5pi over cold. Then corner weight. Under inflated tire will dramaticly alter corner weights.
Old Jun 5, 2007 | 02:24 PM
Evo_Jay's Avatar
Thanks
Old Jun 6, 2007 | 06:55 AM
ure welcome!!!!!!!!
Old Jun 13, 2007 | 01:57 PM
Evo_Jay's Avatar
Another question ... What comes first, corner balance or alignment??
Old Jun 14, 2007 | 06:34 AM
Alighnment.
But, if you're starting with a new adj coilover package, then ride height would be first.
But you should re-check alighnment after corner weighting.
Old Jun 14, 2007 | 11:32 AM
DaWorstPlaya's Avatar
I thought it was corner weight then alignment ... because alignment doesn't affect corner weighting as much as corner weighting/ride height affects alignment.
Old Jun 14, 2007 | 11:41 AM
GTWORX.com's Avatar
alignment -> corner balance -> alignment
That's if you can be bothered. At least get the alignment close before the corner balance, and it won't be too far off.
Suraj, I got good news for you, gimme a minute.
- andrew
Old Jun 14, 2007 | 11:55 AM
Yup, agree with Andrew, to make sure its all right.
I guess Im just used to already being within the ballpark and just making small adjustments. A 1/2 turn on a spring perch is not going to effect alighnment but will on corner weights. And alighnment shouldnt change your corner weights.
So I take it back, corner weights then alighnment. Either way its check, check and check again.
Old Jun 14, 2007 | 12:46 PM
Okay okay, how about this,
alignment -> corner balance -> alignment -> check corner balance -> check alignment -> go check something else ...
I kid, I kid ... ... sorry couldn't help myself ...
Old Jun 14, 2007 | 03:39 PM
Ookami's Avatar
- andrew
He could use some of that, it's all been bad news from what I hear ...
If he's getting KWs, send an extra rebound adjustment knob (I need one)!
3v0luti0n
Aug 10, 2014 08:39 PM
fwd_josh
May 26, 2014 08:06 AM
Sahar.Lancer
Sep 22, 2013 10:20 AM
Deeeeej1973
Apr 6, 2013 10:39 PM
Quick Reply: Corner balance question
