Making my own slotted rotors?
Anyone have experience making their own set of slotted rotors from the stock ones? I've got access to a machine shop, but was wondering if there's anything I should be looking out for or any tiops on dimensions of slots/holes and quantity
slotted are better for track use..
BTW dont know how good you are with machine tools, but I would never do it..
For the amount of time & money you will be spending its much better if you just buy it..
i never said they ran faster at the track or even that they dont crack...
if you want to try to correct my comment good luck because plain and simple...cross drilled rotors dissipate heat faster
ok...im telling you that cross drilled rotors dissipate heat faster than stock ones...
Take a look at maybe the Performance Friction, or Statis Alcon setups, and tell me you can do it better
lol...ok so take a rotor that is cross drilled and put it up agains a rotor that is properly designed... ummmm yeah you are correct....now if that same company made that same properly designed rotor cross drilled it would cool faster than if it werent...
