Does anyone know who to read Ohlins/Eibach Spring Part numbers?
Hello, did quite a bit of research on the net and the forum, but I am still not sure if I got the spring rate of my Ohlins coilover spring. The part is is H200-065-T100 26,06. Does it mean 200mm, ID 65mm, and 562lbs? Can anyone confirm? Thanks in advance. Danny
I can look it up tomorrow at work. Our spring guru will know. I know if you are checking it on a spring rater Eibach uses a different formula than most manufacturers to calculate rate.
In that case the spring rate will be measure in newtons.
So for your spring it will be:
200mm long
65mm ID
100N/mm springs rate = ~10.19kg/mm = ~569.62lbs/in
So yes you got it right in your post.
LCS
Jun 15, 2016 02:26 PM
butters149
Jan 19, 2015 09:07 AM
