E-Brake down, Brake light on???
As the title says, my e-brake is down and my brake light is on... i turned the car off then back on, so on so forth, tried pulling it up and down but as i was driving the brake light stayed on. Any help would be appreciated. Thanks -Matt
the light is in relations with the sensor under the center console..i dont think i thas anything to do with break fluid.
unscrew the screws in the center console and take itout, physically inspect the sensor by engaging and disengating the brake lever to see if the little metal peice is connecting as it is suppose to....i'm sure with a visual inspection you can figure out whats wrong, or maybe the wire attached to the sensor has disc. itself.
bboy_RES
10
Mar 15, 2009 08:17 PM
Bigjoeski05
14
Aug 30, 2006 10:18 AM
