what size tire on 18x9 rim on tanabe springs
i've tried looking onto the forums for the answer. currently im on tanabe gf 210 springs and just recently bought 18x9 rims. im curious as to whats the biggest size i can fit without any rubbing issues. im sure its been answered just having a difficult time finding the answer. thanks
Depends on offset. You can easily run a 245/40R18 but might rub slightly on the fender lining in the front. A 255/35R18 wont rub up front but could slightly in the rear unless you roll/shave the fenders or camber the wheels in (this is not an option with stock suspension and GF-210s). I have GF-210s and plan to run 255/35/18s personally. I then plan to lower the car a tad more with coilovers and shaved/rewelded rear fenders, but that's just me.
TURbev08 summed it up perfectly for you. i have 18x9+29 rims with 245/40/18 tires tanabe gf210 springs and rub up front on full lock of the steering wheel. with the tanabe spings, running a 255/35/18 tire you will most likely rub in the back. with a 245/40/18 you will most likely rub when you fully lock your steering wheel left or right.
it all depends on the overall diameter/width of the particular tire you decide on ( a 255/35/18 falken will have a different diameter, width, shoulder shape, than a 255/35/18 perelli). the amount of camber you run will also effect whether you rub or not
whats the drop on the tanabes. reason being i just ordered 18x9 +30 and i have 245/35/18s comin on them. in the market for springs too and i dont want any issues so i may have to go with something with less of a drop than tanabe if you guys are getting rubbing. basicly i wanna hear from someone who runs 18x9 +30 and has no rubbing what springs you use.
in a few ads i have read the drop is actually less. its 1.5 front and 1 rear so im thinking it should be alright. i just went through the tire business evil. i wanted some azenis but didnt come in the size i wanted. i found that very few tires come in 245/35/18 unless you wanna spend 250 per tire. i went with toyo t1r 245/35/18 ill let you know how they are.
ive been told falken azenis are a pretty good tire for track. if not azenis what other tire would be good to use for drag racing? im a little confused with what tire to go with
gpintoevo9
14
Apr 2, 2009 02:18 PM
