New Girodisc Rotors!
Old Aug 1, 2007, 02:33 PM
dragmod's Avatar
Here is a quick pic of my new rotors i bought from Martin @ Girodisc.
They are a beaut, can't wait to install them this weekend!
They were custom ordered and I got them in about 2 weeks!
Old Aug 1, 2007, 02:35 PM
electricevo's Avatar
those look really expensive. If you dont mind me asking, how much did those run you?
What pads are you planning on running?
Old Aug 1, 2007, 02:37 PM
fastrob691's Avatar
is this a new design, i remember seeing them slotted but not drilled and what are the weights, I am getting ready for the rear and Girodisc was the only one offering significant weight reduction on the rear. Pricing?
Old Aug 1, 2007, 02:47 PM
dragmod's Avatar
The stock front rotor weighs in at 21.35 pounds.
Giro Disc Slotted front rotor weighs 17.4 pounds.
Giro Disc Cross Drilled & Slotted front rotor weighs 17.25 lbs.
The stock rear rotor weighs in at 14.6 pounds.
The Giro Disc Slotted rotor weighs in at 11.1 pounds.
I didn't weigh the rear cross drilled rotor yet but I am sure it is a little lighter than the Slotted Rotor.
I paid about $1750 for the set that was for cross-drilled and custom red anodized hats.
You can PM Girodisc Martin on the site, just do a search for Girodisc rotors.
Old Aug 1, 2007, 02:50 PM
fastrob691's Avatar
Sweet, I have the Baer in the front, no complaints, light, but for quality I think Girodisc is better from what I have seen, hopefully in the next couple months I can get the rears.
Old Aug 1, 2007, 06:09 PM
GTB/ZR-1's Avatar
Thx for posting the weights. I have a full set of (barely) used slotted Girodiscs on their way. Looks like I can expect an approx 15lb roatating/unsprung weight savings--nice...
Old Aug 1, 2007, 09:24 PM
Balrok's Avatar
$1750!?!?! Christ....i can't see spending THAT much for rotors when i'd be destroying them in 4 or 5 events anyways.....
However.....they are damn sexy
Old Aug 2, 2007, 12:25 AM
SICK9's Avatar
Wow, those are nice.
1750$ = ouch.
although , those are the sweetest rotors ever .
very nice. enjoy.
thx for the weights vs. stock.
Any idea what the stopping distance vs. stock are.
Should be alot shorter + cooler than stock, even though stockers arent too shabby.
Old Aug 2, 2007, 07:52 AM
dragmod's Avatar
i casually race and when I do, I am not hard on my brakes. I thought long and hard about getting cross drilled rotors.
I have talked to lots of people with no problems after 6 or more race events with no cracking also mercedes, Porsche, Ferrari, etc...all put cross drilled rotors on their cars.
Basically, if I start really racing I will buy some slotted only rotors.
The slotted ones will run you $1500 plus shipping.
Old Aug 2, 2007, 08:22 AM
dudical26's Avatar
1750$ = ouch.
very nice. enjoy.
I dont think the rotors will really have any effect on stopping distance. Most people upgrade rotors for two reasons. Weight and better heat dissapation.
The stock rotors overheat and contribute to brake fade. Aftermarket rotors have better venting which helps prevent brake fade.
If you want better stopping distance you will need to get different pads or bigger calipers.
Old Aug 2, 2007, 09:46 AM
DaWorstPlaya's Avatar
I wouldn't use anything but blanks or slotted for doing HPDEs and trackdays on an EVO. I'm sure rotor quality also makes a difference but regardless the last thing I want to worry about are my brakes failing on the track. Since you are local , which tracks have you been too?
Old Aug 2, 2007, 12:21 PM
dragmod's Avatar
I have only been to Hastings, but before I moved here i raced at Texas World Speedway, Sebring, Las Vegas Motor Speedway (infield and part oval), Gateway International, Road Atlanta and Motorsport Ranch.
Old Aug 2, 2007, 12:35 PM
*Evil Evo*'s Avatar
nice.. more omaha people in here.. nice rotors tho, i cant wait to start puttin money in my baby
Old Aug 2, 2007, 12:42 PM
WhiteEvo05's Avatar
I know this only for the Porsche "cross drilled" rotors: the holes are cast, not drilled. This helps to significantly reduce the stress risers that develop around the holes. However, they do still crack around the holes and need careful inspection before and after every event, and occasional inspection while used on road.
I suspect the same can be said for Ferrari rotors...not sure about Mercedes.
Old Aug 2, 2007, 03:18 PM
vipers's Avatar
those rotors are gorgeous! i had enough trouble justifying spending 1700 on wheels and tires, let alone brake rotors! but if you got it, why not!
Quick Reply: New Girodisc Rotors!
