Stock metal shim corret position
Hi guys,
I just had my front brake pads replaced at Mitsubishi. During the install process the mechanic put the stock metal shims with the arrow to the up side, whatch direction. Is it correct?
Thanks
Thanks
you are right, I confirmed it at the workshop manual. The arrow must be floor oriented(front), or tire/disk forward rotation.
Unfortunately the mechanic put on the wrong side. Will it cause some kind of brake problem?
spaggiari
Oct 5, 2016 02:13 PM
xexitenglishx
11
Apr 4, 2008 09:33 AM
-Q-
12
Jul 7, 2005 04:07 AM
