PERRIN EVO Positive Steering Response System......
Old Apr 2, 2009, 02:39 PM
  #121
htsai14752's Avatar
bump
Old Apr 13, 2009, 07:52 AM
  #122
nala's Avatar
Any reviews yet? I'm interested in this for my X, but would like to hear some user feedback first...
Old May 9, 2009, 11:35 AM
  #123
inco9nito99's Avatar
Hmm nothing yet..
Old May 9, 2009, 01:06 PM
  #124
wrcRS's Avatar
Hopefully I will get it installed here in the next couple of days.
Next autoX is the 17th. Only problem I see is that you can't run the front control arm bushings (I have the entire Whiteline kit I'm putting in.) Also, I will see what kind of stress is being put on the front bushing of the control arm.
Old May 9, 2009, 08:49 PM
  #125
miragevo's Avatar
Yes, I am also putting in the whiteline bushings and would like some feedback on how much flex you can get out of the whiteline bushing with the PSRS installed.
Old May 15, 2009, 08:50 PM
  #126
miragevo's Avatar
bump
Old May 17, 2009, 01:35 PM
  #127
rovanpera's Avatar
i had this installed last november, along with poly bushes everywhere (energy suspension kit), heim end links front and rear, and whiteline bump steer. stock roll bars.
all together more direct steering feel at all speeds, easier to modulate the car in high speed (80 mph+) turns, no difference in nvh. while i cannot discern specifically since all mods went on the same time, this is a subtle difference.
I RETAINED STOCK CASTER!!.
pk
Old May 19, 2009, 06:04 PM
  #128
Gumby56's Avatar
there are awesome i cant wait to get mine
Old May 21, 2009, 06:49 PM
  #129
top.
Old May 25, 2009, 10:47 AM
  #130
Obviously adding caster is nice but who has first hand experience IN AN EVO?
Old May 25, 2009, 03:34 PM
  #131
18bora's Avatar
It’s hard to tell because I did this and other suspension mods to go with it, i.e. coilovers, whiteline bushings.. etc. My lap times went down by 5 seconds @ NJMP
Old May 25, 2009, 05:19 PM
  #132
Drifto's Avatar
I was under the impression that too much caster actually slows the steering and creates more effort to turn. It's supposed to add high speed stability but slow turn in. I also understand that it dials in neg camber on the outside wheel which is a good thing. How much is too much on an Evo?
Old May 28, 2009, 05:15 PM
  #133
Mitchubishievo's Avatar
I'll be getting this toy next week; I'll add my impressions. I have everything else possible done so it should be a decent way of telling what these really do.
Old May 28, 2009, 08:47 PM
  #134
Zeus's Avatar
I want to do the Caster setup... just have too damn much going on in my life with $$$ going too many different directions.
Too damn many $$$ consuming hobbies
Old May 29, 2009, 08:32 AM
  #135
rawkus's Avatar
I installed the offset (added caster) bushings over the winter. First off... I had to notch the frame a healthy amount to get everything to fit properly. Second, the spacers didn't fit exactly right, but good enough to work. Just a warning, it wasn't the easiest install in the world (It was easier to notch with the steering rack removed, maybe it was just me and my VII).
I also installed the Whiteline Roll Center and Steering Feel kit as well as the AMS Rear Trailing Arm bushings, so I can't specifically speak of just the changes due to the PSSR. Ride quality isn't bad at all, unless I hit a really sharp bump, like a train track or pothole. Stability is incredible, if feels as if you always know what the front wheels are doing. I can brake hard while starting my turn in and have no ill effects at all. I also have done a day of drag racing with them and had no issue with wheel hop whatsoever.
I would recommend them, but caution that unless you really, really want added caster, consider going with the centered bushing.
Dan
Quick Reply: PERRIN EVO Positive Steering Response System......
