installed Megan coilovers and.....
well lets start by saying that they are a b i t c h to adjust. they got tighter the further i lowered the car. couldnt figure that out.
so i installed them last night, adjusted them all up. just went out to my car to check on all the bolts and when i removed my trunk carpet, the rear driver side was all wet. i have no idea y or how it was as wet as it was. its not raining, nor was it this morning. i didnt go over any puddles. and its water too, not oil or anything like that. was just all wet.the other side wasnt wet at all. any sugestions as to why or how this has happened?
and to the "O" comment, my car has good taste, what can i say.
i measured from a level surface to the top of the fender and...
fronts are 25"
rears are 24.75"
now i know this isnt the correct way to measure them because of tire height and whatnot but all tires are at 35psi.
fronts are 25"
rears are 24.75"
I have Megan Street. You're a little lower than I am, but I didn't have any issues lowering whatsoever.
I aplogize if this seems dumb (I'm as new to coilovers myself), but you loosened just the bottom lock to adjust?
No idea on the wetness, maybe some Depends for your car?
If it was geting tighter as you adjusted it, that spring was not spinning with the rest of the assembly (shock, spring perch, spring perch lock). The fronts won't have that issue because there's usually some sort of spacer/ring/washer between the spring and mounts at both ends to allow it to spin relatively freely, due to how a spring tends to twist in a mac-strut setup. In the rear, sometimes the spacers are left out, and the spring might "stick" and not turn along with the shock when you're adjusting, hence you're fighting against the friction of the threads spinning in the lower collar AND the force of the spring.
and as for the leaking issue, what if i used some sort of like silicone to make a seal
