Whiteline Roll Center Correction kit--need some help
Old Dec 26, 2007 | 11:43 AM
cfdfireman1's Avatar
Good luck finding the right size you must push on the very outside edge of the ball-joint not the center. I call those hammers but it don't make it right.
Old Dec 26, 2007 | 02:51 PM
belizelittle39439's Avatar
It fit actually...I just needed to press the ball joint up just a smidge more. Those snap ring pliers helped out. I also bought the c-clamp ball joint installer/extractor to make the other side a little easier. I got it in with the separator tool, but again, it wasn't too pretty.
I'll do a "how to" on the other side, it shouldn't take more than an hour or so since I now have all the proper tools and did the dry run on this side.
Old Dec 26, 2007 | 03:30 PM
civicevo380's Avatar
^^Like you said, you realy need to press those ball joints in all the way. Good luck.
Old Dec 26, 2007 | 04:54 PM
I really think you'll save time if you take the lower arm off and do it on the bench.
Old Dec 26, 2007 | 11:39 PM
Theoretically. Unfortunately Mitsu overtorqued the lower arms so tight that even at 150 psi with the gun--neither of the inner bolts would come loose, that's after shooting it up with PBlaster too.
That was my intended plan, until all this happened. So I went with the hub removal method instead. Pretty easy either way, assuming you can get the bolts off without issue (and you have the right tools).
Old Dec 27, 2007 | 09:42 PM
Jeff_Jeske's Avatar
^^^ A large pry bar and solid socket wrench loosened them up with ease.
Old Jan 3, 2008 | 08:17 PM
Wanna give me your secret technique then for future reference?!
Ironically I JUST got done with the ball joint on the driver's side...so now the front is done. Roll center correction kit has officially been installed. The only things I had a problem with this time was when I pressed out the joint, not only did the joint come out, but somehow the lip on the bottom of the arm came off with the joint! I mean the **** just tore right off! Since it doesn't actually hold anything though, I guess it's not a big deal. But damn...
When I pressed the joint back in, I noticed it started going in sorta ****-eyed about halfway through, but I couldn't do anything at that point but continue to press it in...ended up with a little more aluminum shavings that I'd had liked but the joint is tight and the snap ring is secure.
Now all I have to do is the rear bump steer correction kit, and then I can go get her aligned.
Old Jan 5, 2008 | 07:08 AM
prostcj's Avatar
Looking forward to installation instructions. I'm debating whether or not it would just be easier to have the kit installed at a shop.
Old Jan 5, 2008 | 07:37 AM
The roll center kit isn't too bad of an install...the tie rod ends will take about 10 minutes to do, the ball joints a bit longer depending on your experience level and the tools in your repotoire.
Just make sure you have an adjustable pitman arm puller/ball joint separator for the tie rods. I bought a kit, but only used on piece of it. I used that same piece to install one of the ball joints even--though I wouldn't recommend it if you can get the arm off and simply have a shop (or you) press it in with a shop press.
Pep boys had a 20-ton locally for $150....about the same thing that labor would cost if you went to a shop I suppose. Worth it in my opinion.
Old Jan 5, 2008 | 07:50 AM
prostcj's Avatar
My goal is to get the arms off and have a shop press the parts in.
Old Jan 5, 2008 | 11:32 AM
Lazyfong's Avatar
Let me know what shop you are going with to use their press. I plan on doing this install most likely in the spring. Also, what place do you plan on getting the alignment done? Figured I will ask since you live in Illinois like me.
Old Jan 5, 2008 | 11:44 AM
prostcj's Avatar
I live in Central IL. If you can get the arms off yourself, take it to just about any auto shop with a press and it should be a 10-15 minute job for them to swap the bushings. I'll probably go to a local place. I'll post what I end up doing and how it worked out.
Old Jan 5, 2008 | 09:19 PM
^^ bushings or ball joints?
Old Jan 6, 2008 | 05:12 AM
prostcj's Avatar
OK, got me there. I'm also having the rear bump steeer kit put in and I think of that kit as a bushing set. My roll center kit hasn't arrived yet.
Old Jan 18, 2008 | 09:03 AM
SHhhhh's Avatar
I just picked up my Whiteline Roll Center kit for $154.99 shipped! This is a great deal and I got them in 2 days from ordering.
I am in no way affiliated with this company, but just wanted to share my experience with them.
http://www.maperformance.com/store/p...roductid=18450
Quick Reply: Whiteline Roll Center Correction kit--need some help
