StopTech BBK 332mm
If you are looking at an older used 4 piston front and rear kit, it will still be balanced. The older 4 piston rear setup required larger front pistons than our standard front only kit becuase we couldnt get the torque output low enough to balance with the front only kit. With the introduction of our 2 piston calipers a few years ago, we were able to get the torque output in the rear to the correct point where it was compatible with the front only kit.
Don't worry about it man, the picture you posted up is of a 4 piston front\ 2 piston rear kit. Just look at it and you'll see that it looks like the stock rear Brembo set-up ie two pistons.
Would the balance get too far out of whack with a Stoptech 332mm front and stock Brembo rears? Or is it really worth the extra 1900 to get the 2 piston Stoptech rears to replace the Brembo 2 piston rears?
CityTireOnline
EvoX 'For Sale' Suspension / Brakes / Handling
Apr 26, 2010 06:57 AM
InjectedPerf
Evo 'For Sale' Suspension / Brakes / Handling
11
Nov 19, 2009 11:37 PM
Vivid Racing
17
Nov 5, 2003 08:31 AM
