high speed brake vibration question
Old Jan 16, 2008, 07:38 PM
EvoM Community Team
atombomb33's Avatar
He's got uneven pad deposits on the front rotors. Go out and rebed the pads per the instructions that came with your BBK. If that doesn't work, then you'll have to take the rotors in and have them cut.
Old Jan 17, 2008, 05:01 AM
my04s2k's Avatar
get some ds2500's and go through the bed in process. that will clean those rotors quick.
Old Jan 17, 2008, 08:48 AM
20psiMR's Avatar
Originally Posted by Vapor
call me crazy, but i think I'd start with the known defects first. Alignment and bent wheels could easily cause this problem. I'd start with the alignment
Normally I would agree, and I think those things need to be addressed asap. However they have nothing to do with the problem he described. If those were the issue, they would happen all the time. He said he is high speed braking, which typically means he is into the pedal pretty good. Thats when you will notice pad deposits, especially heating up the rotors like that without bedding pads properly.
The whole thing stems back to bedding, plain and simple. It really is surprising how often it does actually.
Old Jan 17, 2008, 11:52 AM
cfdfireman1's Avatar
^+1000
Old Jan 21, 2008, 01:48 PM
bluemm's Avatar
thanks guys, i will try a few things and report back.
Old Jan 28, 2008, 08:25 PM
KeithD's Avatar
Your rotors are warped
Old Jan 28, 2008, 09:11 PM
Balrok's Avatar
It's also worth noting that bent rims/alignment will also cause minor vibrations at high speeds (this goes back to wider stickier rubber/bigger wheels = better braking for obvious reasons) So if he's getting into the brakes hard and only feeling it through the wheel, i'd lean more towards that then the pad deposits, however it sounds more like a combo of both from the methods he has described using. Think of the pressure you put on the wheel/suspension/tires at speed, then combine an uneven wheel/crooked alignment with that, it's like the wheel would be going /\/\/\/\/\/\/\/\/\/ down the road which is more noticeable at high speed - and you'd only notice it through the steering wheel.
Old Jan 28, 2008, 09:20 PM
Slovo's Avatar
Rotors seem to be warped, if ya got stock pads they tend to heat up the rotors alot, Hawk pads seem to do well with the heat dissapation..... Resurface ur rotors and see how the drive is..
Allentotora
Jun 5, 2017 12:20 PM
slicksta69
15
Jun 20, 2016 09:23 AM
turbotaloon95
Jan 23, 2015 06:48 PM
raytrix
22
Jun 19, 2010 04:39 PM
jxs1984
19
Apr 20, 2009 12:20 PM
Quick Reply: high speed brake vibration question
