psi
Old Jan 26, 2008 | 01:27 PM
veilside prius's Avatar
psi
whats psi are you guys putting in your tires? and wat mpg and tire size please, I'm trying to find optimal tire pressure.
Old Jan 26, 2008 | 02:21 PM
Disrupt's Avatar
Shouldn't it say what psi on your tires?
Old Jan 26, 2008 | 02:25 PM
Johnboy1065's Avatar
yeah it should say on the tires. but at the drag strip. let some psi out of them to get better traction
Old Jan 26, 2008 | 02:28 PM
Evo11V's Avatar
Veteran: Army
strip 21 PSI is best I hear. Normal driving I run the normal pressures
Old Jan 26, 2008 | 03:14 PM
LuvEvolution's Avatar
actually, if you wanted to get technical, you should run whatever pressures are listed on the sticker that's on your drivers door and not what it says on the tire. the tire is ALWAYS a maximum pressure and not a running pressure. hope that helps.
Old Jan 26, 2008 | 04:12 PM
Dont Try To Run's Avatar
About 2-3 PSI less then what the tires says is what I have heard. Less pressure=better handling but worse mpg. More pressure=worse handling but better mpg. Just adjust how you see fit, but don't take a turn too quick with Full tire pressure because you will not grip as well as before
Old Jan 26, 2008 | 06:47 PM
krazirob's Avatar
i bring my front down to 19-20 on the strip and a little on the back but on the road i wanna say i bring mine to 28 or so.......cant remember
Old Jan 26, 2008 | 10:46 PM
gixxer6's Avatar
I run 31 up front and 29 in the rear
Old Jan 28, 2008 | 07:53 PM
KeithD's Avatar
on the street run 32 in the front and 29 in the rear. at the strip about 20 or 21 all the way arround
