Do I Deserve New Tires?
I have exactly 1000 miles on my car. As soon as I drove it off the lot I noticed that it was out of alignment and pulling to the left. At about 200 miles I took the car in to have the alignment fixed. They said they fixed it. But when I left the dealer it was still not fixed. At about 750 miles I took it back to the dealer to have the fix the alignment. And of course they still did not fix it. This time he even said "I made sure to get the factory specs this time"
So I call my service rep and tell him that it is still not aligned. He says that he did it to factory specs and that I should take it to another dealership.
This gets me to today. I call a second dealership to make an appointment to get my alignment fixed and ask about the tires getting replaced because driving on non-aligned tires for 1000 miles will have a huge effect on the longeity of high performance tires. The dealship says to call Mitsu of America which I do and Mitsu of america is its the origional dealers responsibility to replace my tires. So now the original has 48 hours to call me.
Am I entitled to new tires because driving 1000 miles on non-aligned tires will definatly have an effect on the life of the tires?
well at a minimum they should have to pro-rate the tires for you. you have probably 90% tread left so they owe you at a minimum new tires at 90% off. I would say they owe you new tires though
I have an OZ and after 9000 miles the tires were wearing really bad on the outside and there was hardly any wear in the middle. I went to the dealership and they said they don't cover tires but it was obviously an alignment problem so i ended up calling yokohomo and they paid for new tires. I'm not sure what tires are on the EVO but try calling the tire manufacturer if there starts to be uneven wear. Mine were supposed to last 20000 but since they were completely bald after 9000 they paid for the new ones. The dealer did jack.
Craig
Craig
This should be in general. Its not a question of tire wear rather a question of dealer responsibility. Could someone please move it back.
Thanks
Also I know that they are out of alignment because the wheel is turned like 5 degrees to the right. If i hold the wheel straight my car goes to the left
Thanks
It's alignment troubleshooting that is why someone sent it here.
The steering wheel being off means nothing as far as alignment.
All it means is the tech did not have it on dead center when he se the alignment. I could align the car perfectly and put the wheel off by 90 degrees and it will drive fine.
Are you even showing odd wear on the tires? And why is it their responsibility if you drove it for 500 miles before gonig back again?
Thanks
Thanks
timzcat is right. The car can be perfectly aligned with the wheel not centered.
If your sole reason for believing that the car is out of alignment is that the car turns left when you hold the wheel straight, then there is likely no problem with your car.
The point is, the alignment is probably right, just the steering wheel is off-center. Take it back to the original dealer and tell them the steering wheel is off-center and you want it fixed. Have them check the alignment just to be sure it is in spec.
I think most of us who have an Evo have jobs, too.
You picked it up the first time and the wheel was off-center, why not turn around and give it back? How does a alignment make a car unreliable? You have any idea how many cars come out of the factory with poor alignments, from every car maker.
El Jefe
A car can be in-spec on alignment and still pull or veer. I had an alignment done on a different car, everything within Toyota's specs, but it pulled hard to the left. I looked back over the sheet, and several areas were at or near the extreme - I had the max toe on my left wheel and min toe on the right, both still in spec, but the back of the car was basically turning.
Lesson: get a copy of the final alignment sheet, look it over, and make sure everything is fairly "middled". If everything looks ok, go for a quick drive at a variety of speeds. If it's not right, turn around immediately and get it fixed. That you waited 200 miles the first time and 550 miles the second time would lead me to say you are on your own for the tire wear.
Incoming flame....everyone duck
Some of you guys are such ******. Saying its his fault for the tire wear because the dealership didn't align the tires properly and he didn't turn around immediately. Some people don't have four cars laying around and actually wanna have their car and maybe he actually trusted the dealership to do it right and didn't even realize it was messed up to begin with. So just lay off, its the dealerships fault.
As soon as I notice the problem I call the dealer and make an appointment to bring the car in.
