255/40/18 with 2 inch drop?
Will 255/40/18 tires on 18x8.5 volk te37 time attack wheels with 30mm offset. fit on a Evo IX MR without rubbing? With 2 inch drop...
you'll get rubbing on your front liner if you're that low. If you take it out you'll be okay, not sure about hard cornering. It depends if you are going to do coilovers or lowering springs.
ill be gettign seibon carbon 10 mm wider front fenders... and ill probably roll the rears... my question is. will there be downsides to rolling fenders to run 255 wide?
I was going to post the same question. I have the same volks 18 x 8.5. Not sure of the exact offset but assume its about +30 (kinda flush). Im between 245's and 255's. Im currently lowered on Swifts and have gotten rubbing w/ my current 245 BFG kdw Gforce's. It was rubbing in the front inner fenders when the wheel was turned.
The width isn't too much of a problem (well, the rear might rub a hair since you are +30, but it's only an 8.5" rim so you will probably be ok). The height is the problem: stock is 25.3" those are 26.1". It will cause you to rub on the fender liners. That's why most people run a 255/35/18.
WTB[Northeast]: Few Parts and Pieces
119Evo
May 2, 2016 06:28 AM
WarmMilk
Oct 17, 2011 06:55 AM
AmF_15
Jul 19, 2009 10:26 AM
