18X8.5 +33 with 245/40R18? Fit OK?
Old Mar 15, 2008, 10:09 PM
YetiEVO's Avatar
I'm looking to get a set of Gram Lights Optimise in 18X8.5 +33mm and run 245/40R18
on them. I have an Evo 8 and the suspension and brakes are stock. I've already searched and plowed through several of the exhaustive threads on wheel fit and tire size - everything I can tell leads me to believe this size will work w/o rubbing and no fender-rollling. Unfortunately, no one is running this exact combination. Closest I could find was Trinydex with Gram Lights 57S in 18x8.5 +30 with 245/40R18. I'm wagering that if his fit, then the 3mm difference is tiny and my combo should also fit.
Anything I'm missing that would make this a bad fit? Would 255/35R18 be better? (Not sure which is worse, the larger OD of the 245/40R18 or the wider 255/35. I know the 255 has about the ideal OD.)
Wheels & tires are a lot of $$$ for me to spend - wanna get it right! Your opinions?
Old Mar 16, 2008, 10:13 AM
YetiEVO's Avatar
Been doing more research -
Is 17x8.5 +30mm with a 255/40R17 a better way to go?
I'm looking to get more contact patch and avoid rubbing. I got onto the idea of 18's because I found a deal on the rims, and they'd look cool. Not the best setup for the track tho...
Again, the car has stock suspension and brakes.
Buehler? Buehler?
Old Mar 16, 2008, 10:22 AM
Murf's Avatar
contact ROBI on this board..or search robispec you will find him..pm him or call him about his Enkei NT-03+M set-up. and yes a 17 is a better way to go. with some work I believe he has a 17x9 that will fit with no rolling.
Old Mar 17, 2008, 06:28 PM
YetiEVO's Avatar
For the lurkers out there:
I went with the 17X8.5 +30mm with 255/40R17 Dunlop Direzza Z1's. Now I have to wait weeks for them. Tires are on back order. When I got 'em, I'll post em up.
GTijoejoe
Aug 2, 2016 09:06 AM
kaonashi
Aug 9, 2013 05:42 AM
Inprogress
11
Sep 30, 2012 09:30 PM
Blitz
Jan 15, 2012 01:41 PM
Silver06evo9mr
56
May 21, 2007 05:10 PM
Quick Reply: 18X8.5 +33 with 245/40R18? Fit OK?
