What's going on with my brakes?
Hey guys,
Here is the low down. Three days ago I went to get my brakes serviced (I had front end vibration when applying the brakes). My dealer ended up replacing the pads and resurfacing the rotors under warrentee. Now the brakes squeal when I hit the brakes and turn left. My dealer said that it was normal "break-in". The squealing is loud. Can anyone help out?
Bobby
Bobby
BLKevo8,
Get the service dept to look at it, the vibration will only get worse. The pads apparently build heat too fast and end up warping the rotors......they said to take it easy on exit ramps (bs if you ask me)
Bobby
Bobby
Originally posted by HwangTKD
Mayhem,
Quick question, why would it be normal if it happens only when I turn left and brake?
Mayhem,
Besides, you should do all your braking in a straight line then start your turn in..
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
Good luck, I wouldn't worry about it too much.
mine wheel seems to be getting quite a bit of vibration in it as well... i had my pads replaced the day after i bought it, cause whatever yocal test drove it, must have really abused the brakes... there was pad transfer on the rotor, so they resurfaced them as well...
i need some 2 pc rotors like now...
![Bouncy Blob](https://www.evolutionm.net/forums/images/smilies/b_yellow.gif)
dealers sure like to define normal to suit their own purposes. I would examine the pads for glazing and, if found, I would show it to the dealer. Then, after they accused me of abusing the brakes during break in I might do a very light sanding (Caution: just enough to remove the galze from the pads) then re-fit and try to mate them to the rotors once again.
Too bad they resurfaced your rotors, unless there was scoring or warpage they just did a number on you.
vibration is from warped rotors pushing teh pistons back in and/ or pushing the tires out and in to follow the rotor(hence vibration and pedal pulsation). i would have asked for new discs since it is a hi-po car the thinner the rotors the faster they will give in to heat
Lightsaber
Dec 9, 2016 01:02 PM
4g63xawd
62
Jan 6, 2016 03:25 AM
aZnLaNcEr
Dec 27, 2005 12:52 PM
