Hawk Pads
Hawk Pads
Any comments on them? I just bought them and im going to install them today. Also, is it like a normal brake pad replacement or do i need any special tools?
Thanks for the comments and any help.
The Brembo calibers are the easiest to replace due to the rear openings to pull out the old pads. Just carefully use the punch to pop out the pins, you don't want to nick the Powder coating on the calipers they will begin to peal : ( As far as the Hawks go they should be great, I am running the Ferodo racing pads now and I love them. Let us know how the Hawks work.
Good luck
Good luck
Good luck
Good luck
Check out this link http://media.putfile.com/Brembo-brak...nging-tutorial. It will show you the pins he is talking about.
i think there are several models for the hps pads which is why some guys experience noise while others don't. just came across in a vendor's website 2 different part numbers for the hps front pads.
We are very experienced in selling brakes &c to the German car guys. I am not advertizing, just sharing our experience.
Hawks are dusty and with some compounds tend to leave an unremovable residue when used hard in wet conditions - unremovable in that no amount of effort short of bead blasting removes it - DTC series is better in this regard. Their street ceramics squeel like pigs but are good stopping, long lasting and virtually nondusting (yes we have antiseized the he11 out of them to min squeeling!); if it weren't for the noise we would rate them a perfect street pad.
Nearly all our performance guys have gone to Performance Friction: street guys the Carbon Z cpd and racers the various 01, 03, & 07 cpds. The success has been phenomenal! I was always a Pagid guy so I resisted this until I tried a set; now I'm a convert. Price is HIGH but wear is best, dust is minimal, performance will suck your eyeballs out, rotor wear is minimal even in the race pads! Other pads we have had success with are:
Ferodo - great stopping but dusty and pads wear quickly with little rotor wear
Pagid - great stopping but dusty with good pad wear and little rotor wear
AXXISS Ultimates - street only guys love them for wear low dust but melt at track
BTW, ask your vendor to source the Performance Friction 2 piece rotors - they are incredible. Don't know if they are available for the Evo X yet but our BMW and Porsche guys love them!
I am not stating this is gospel but unlike private users I do have hundreds of data points to support these claims. Use the info as you see fit when buying pads from your supplier; he'll probably confirm this for the pads he carries.
Dan Law
DER MotorSports
Dan Law
DER MotorSports
i just got the hps as i was thinking of trying out the dtc 60 for track. is it ok then to run hps and swap it out for pfc 01 during track? i understand it's better to run street and race pads from the same manufacturer.
