Pillow Ball Mounts, Bolts, egg-shaped, stripped bolts? Not sure whats up here..
Hey everyone,
I bought a set of PSS9's from a very reputable member here on EvoM. I sent the dampers to Bilstein for revalving for 12k/16k spring rates, and decided to inspect all of the pillow-ball mounts and other misc. hardware that came w/ the package.
Unfortunately, a lot of the bolts and the top mounts look funny. See pics:
Am I going to have to replace all of this hardware? Do they sell just the misc. bolts?
Here, the hole is all egg shaped. No idea why?
These two top mount bolts are all stripped out in side.
The top mounts on the rear look messed up (the inside parts)
Two other spacers are all egg-shaped too.
Call TEIN or a knowledgable TEIN dealer (rallysportdirect), and show them the pics.
You'll at least need new topnuts, and maybe the whole bearing for those rears. They look a little messy. See what they say.....they'll certainly be able to help. Rallysport can get you replacement parts.
My guess is whoever put these on pounded the bejeezus out of the topnut with an impact gun!
- Andrew
- Andrew
Personally I wouldn't use any of that hardware. I've also owned a couple of Tein products and never had any of it look like that.
My guess is this:
The PSS9's have a slightly different thread on the end of the damper shaft and these parts were reworked to fit that damper shaft. Whomever did the work however is a hack.
Edit: Contact Bilstein and find out the dimensions and thread of the damper shaft. Then contact Tein directly and find out their dimensions and thread and see what jives and what doesn't.
Good Luck
John
My guess is this:
Good Luck
John
Andrew,
Thanks for the input man! I just got off the phone w/ Rallysportdirect and they're sending the link to this thread to a guy who should be able to help me.
John,
Good point. I will call up Bilstein and see what the dimensions are of the thread/dimensions of the shaft.
Andrew (again),
Would you know the dimensions of the Tein plates and what shafts they would be able to accept?
John,
Andrew (again),
I just don't want to replace all of these parts and have this happen in my car! Especially at the track if something like this broke... that would be bad.
My guess is this:
Good Luck
John
My guess is this:
Good Luck
John
- andrew
...dammit.
crazy4ozs
Aug 12, 2007 03:43 PM
