drilled or slotted rotors?
Old Apr 16, 2008, 11:52 AM
landis507's Avatar
for street use, stopping fast and stil being able to use the bakes after a couple stops
Old Apr 16, 2008, 12:00 PM
EvoHung's Avatar
For street use I think they will both do fine. You can really benefit from cross drilled and slotted rotors if its only street use you are wanting. If you do some heavy duty racing then one of those are prone to cracking. I'm not sure but I think it might be the cross-drilled, or was it the slotted? Can someone chime in?
Old Apr 16, 2008, 12:04 PM
landis507's Avatar
yeah its just street use, i was thinkin the brembo stolled or drilled.
Old Apr 16, 2008, 12:05 PM
tvbf1's Avatar
Cross Drilled crack in race applications.
Old Apr 16, 2008, 12:06 PM
ustcc evo's Avatar
Plain rotors are the best.
drilled rotors are no longer necessary with modern pads since they no longer 'out gas'...pure bling...and just gives more places for cracks to start propagating.
Slotted helps a little by ensuring a clean pad face if you glaze them by overheating, but isn't really necessary, and makes the brakes very noisy for the street. Also increases pad wear significantly.
It's all bling at the end of the day...I race on plain rotors unless I have to run something else.
Many threads on this topic...
Old Apr 16, 2008, 12:08 PM
landis507's Avatar
i found some rotora stolled/ cross-drilled rotors. would those be the best for street use
Old Apr 16, 2008, 12:09 PM
landis507's Avatar
ok so nevermind the drilled rotors, lol. ill go with slotted. just to help a little
Old Apr 16, 2008, 12:10 PM
max2evoix's Avatar
drilled
Old Apr 16, 2008, 01:00 PM
turbo271's Avatar
plain
Old Apr 16, 2008, 01:08 PM
meckert's Avatar
Slotted- helps clean the pads and keep the pads from building up debris..my /.02c. Worked for me.
Old Apr 16, 2008, 04:08 PM
Solo II Evo's Avatar
Perfectly stated.
Old Apr 16, 2008, 04:38 PM
Jacek's Avatar
I would choose drilled, just because they look cooler lol
Old Apr 16, 2008, 05:59 PM
Kins's Avatar
Drilled are prone to cracking so I would avoid.
Slotted ftw, they take off the "glaze" that builds up under light breaking.
Down sides are: noisy until pads and rotas bed in.
Increases brake dust.
Increases pad wear.
Plus sides are you stop quicker because there is no glaze.
Old Apr 16, 2008, 06:11 PM
P-ROY's Avatar
Go slotted
Old Apr 16, 2008, 06:15 PM
Dabaysevo's Avatar
Centric blanks for street use.
Quick Reply: drilled or slotted rotors?
